Rev-up + test pipes = CEL ?
Old Oct 15, 2006 | 11:54 PM
Mazinger Z's Avatar
Mazinger Z
Default Rev-up + test pipes = CEL ?
How many of you have have test pipes/res. test pipes/ HFC's and have CEL's ? I read that some do the non-fouler fix and still get the CEL...true/false?
Edit: This is on the rev - ups.
Old Oct 16, 2006 | 10:13 AM
Racerbmx87's Avatar
Racerbmx87
i did the non fouler/ghetto sim, i got a check engine light roughly 50 miles after i had it, and then took it to autozone, had it reset, and hasnt come back since. 10k miles since then right now, ses light free
Old Oct 16, 2006 | 10:15 AM
Mazinger Z's Avatar
Mazinger Z
By reset, what do you mean? You reseted the ecu? Or did autozone do something?
Old Oct 16, 2006 | 10:26 AM
Racerbmx87's Avatar
Racerbmx87
by reset, i mean that i just told the guy at autozone to clear the code. the guy was really hesitant to do so, but i convinced him to.
or you could unplug ur battery for like 5 min and let the ecu reset itself, i think that should work.
Old Oct 16, 2006 | 12:13 PM
97supratt's Avatar
97supratt
I have a 06', I installed test pipes the first week I had the car. Always install non foulers on the 04.5 + motors. So in your case, your 06' needs non foulers. Once you install them, you can do a soft reset by disconnecting the negative battery for a few minutes or the technosquare foot pedal reset.
good luck
Old Oct 16, 2006 | 07:12 PM
btchnzcar's Avatar
btchnzcar
How do I tell if I have a pre or post 2004.5?
Old Oct 16, 2006 | 07:47 PM
QuadCam's Avatar
QuadCam
no prblems with test pipes on my revup. the muffler shop made up a set of non-foulers.
Old Oct 17, 2006 | 07:52 AM
97supratt's Avatar
97supratt
Open your door, there is a sticker on the side which states the gross vehicle weight and OEM tire sizes, you should also find the production date which will determine if your vehicle is pre or post 04.5.
Old Oct 17, 2006 | 07:42 PM
btchnzcar's Avatar
btchnzcar
Thanks!
Old Oct 17, 2006 | 10:03 PM
Mazinger Z's Avatar
Mazinger Z
Ok, back to the topic at hand...anyone else comment?
Old Oct 18, 2006 | 01:32 AM
Acree's Avatar
Acree
For the short period of time I had test pipes on my 05, I never had a CEL come on. I didn't have any kind of non-fouler fix either.
-Acree
Old Oct 18, 2006 | 07:14 AM
97supratt's Avatar
97supratt
-Acree
It would have turned on eventually. It not if, its when it will come on.
Old Oct 18, 2006 | 08:05 AM
Acree's Avatar
Acree
See I was told that if they don't come on right away, that they wouldn't have come on. I drove the car 3-4 different times for more than 5 minutes each time, and they never came on.
So you're saying it takes a while?
-Acree
Old Dec 17, 2007 | 02:06 PM
Mazinger Z's Avatar
Mazinger Z
Reviving an old thread...
I just installed Fast Intentions res. tp's on my revup and the cel came on after about 30 miles of driving. I have non-foulers installed and was careful not to damage the O2 sensors. Will a "soft reset" fix it? I know the CEL is my tp's but I'm probably going to autozone to check out the code anyways. Rev up owners w/ tp's help please! How did you keep it off?!
Old Dec 17, 2007 | 02:11 PM
blueper4mancez's Avatar
blueper4mancez
just disconnect toe negative battery terminal man . i had test pipes on my car for a whole year without a cel .
Old Dec 17, 2007 | 03:26 PM
Mazinger Z's Avatar
Mazinger Z
^Thanks, I'm doing that right now. Some rev-ups will throw a cel some won't.
I checked out the code, it's P0420 Cat efficiency threshold (bank 1). Which side is bank 1?
Old Dec 17, 2007 | 04:52 PM
Reality350's Avatar
Reality350
I had TP's with non foulers on my 35th, no cel's at all.
If you do throw a cel, simply reset it.
Either peddle reset or disconnect your NEG terminal and hold down your brakes for about 2 min.
Old Dec 18, 2007 | 03:53 AM
RBlover69's Avatar
RBlover69
HFCs on a revup no cel....
Old Dec 18, 2007 | 06:25 AM
meaj82's Avatar
meaj82
I'm going on about 10 mos w/ no CEL. I had it at first and then did the reset procedure and it went away and has never came back.
Old Dec 18, 2007 | 06:56 AM
gothchick's Avatar
gothchick
I got a CEL at first on my TPs with non-foulers. Did a soft reset via a scanner. Haven't had another CEL in about two months.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
