JWT PopCharger Filter Cleaner
Old Oct 27, 2006 | 10:58 AM
tmounk's Avatar
tmounk
Default JWT PopCharger Filter Cleaner
For the guys with pop chargers, what cleaner and oil do you use on your filter. I don't want to use the k&n cleaner because it has a red tint. I found this cleaner but is it a cleaner or oil gaze?
http://www.jimwolftechnology.com/cus...asp?PartID=355
Old Oct 27, 2006 | 11:01 AM
Jenn350Z's Avatar
Jenn350Z
I would think it'd be the same thing no?
That one you posted is an oil.....
Old Oct 27, 2006 | 11:17 AM
drifter23's Avatar
drifter23
You should go with the K&N filter cleaner kit. It comes with the cleaner and red air filter oil. And can be purchaed at most autoparts stores. As the link you attached is just the blue air filter oil.
Old Oct 27, 2006 | 11:18 AM
drifter23's Avatar
drifter23
Originally Posted by dave079
Use K&N cleaner and use the JWT filter oil if you want it blue
+1
Old Oct 27, 2006 | 11:24 AM
sluggoZ's Avatar
sluggoZ
I bought mine from performance...it has instructions on cleaning...very simple. Just don't over oil!
http://performancenissanparts.com/ca...roducts_id=264
Old Oct 27, 2006 | 11:41 AM
Cannysage's Avatar
Cannysage
easier to pick up k&n from any shop. pepboys or kragens.
Old Oct 27, 2006 | 03:19 PM
tmounk's Avatar
tmounk
I use k&n on my aem cold air on my accord, but is the blue oil better for the filter than the k&n?
Old Oct 27, 2006 | 03:28 PM
zand02max's Avatar
zand02max
Just a color difference. Like folks said above, the K&N has a cleaner, JWT does not!
Old Oct 27, 2006 | 03:32 PM
jondimellow's Avatar
jondimellow
i heard that k and n oil isn't that great from a local hot rod shop. they suggested i use holley air filter oil.... there is a kit with cleaner and oil for like 20 bucks.
Old Oct 27, 2006 | 03:33 PM
zand02max's Avatar
zand02max
BS! Been using K&N for over 10 years! Not one problem!
Old Oct 27, 2006 | 07:11 PM
Chad68's Avatar
Chad68
I used K&N on mine.
Red, blue what's the big diff?
Matches my car now.
Old Nov 10, 2006 | 06:06 PM
DanielW's Avatar
DanielW
how often do you guys clean your pop charger?
Old Nov 10, 2006 | 06:10 PM
zand02max's Avatar
zand02max
Your killing me DUDE!
Old Nov 10, 2006 | 08:44 PM
DanielW's Avatar
DanielW
cool
Old Nov 11, 2006 | 06:02 AM
semtex's Avatar
semtex
From the K&N FAQ:
20. How do I know when to clean the filter?
The general rule of thumb is that the filter needs to be cleaned when the dirt build up gets as thick as the wire mesh. The usual interval is 30,000 - 50,000 miles depending on driving conditions. We recommend that you check your filter about once a year in normal usage.
http://knfilters.com/faq.htm#19
Old Nov 11, 2006 | 04:28 PM
Z04's Avatar
Z04
409 cleaner works great on the filters. a lot less expensive as well.
Old Nov 11, 2006 | 04:30 PM
plumpzz's Avatar
plumpzz
Simple green works nice to degrease. Also, any dishwasher. I let it soak in soapy water for an hour and then hose it out, let it dry and then oil it and let it dry again. Once i didnt let it dry and when installing my plenum, i noticed a ton of oil inside the plenum. Also, when i let the intake sit on the floor, there was a pool of oil on the floor from all the oil finally coming out.
Old Nov 11, 2006 | 04:33 PM
zand02max's Avatar
zand02max
I normally clean and re-oil mine at night, that way it sits on my garage bench over night.
Old Nov 11, 2006 | 04:36 PM
jtabraham's Avatar
jtabraham
The key is not to over-oil it. Too many people saturate the filter, and all that excess oil flying into your plenum will mess up your MAS
