Wierd Smell After Install of my new Stillen TD???
Old Nov 2, 2006 | 01:55 PM
DanielW's Avatar
DanielW
Default Wierd Smell After Install of my new Stillen TD???
hey guys i just had my stillen td installed and i noticed everytime i would get to a stop light a strange smell would come into the car. not to strong but deffinitely there. and then when i got home and got out of the car i could smell it as well. It smells similar to if you left the e brake up. And no, i didn't leave the e brake up. Anyone else experience this? Is it normal?
Old Nov 2, 2006 | 01:59 PM
schweatty's Avatar
schweatty
aftermarket exhaust gets hotter than the OE (no sheilds etc...). its your paint on the undercarriage being heated up. once the paint cures at the higher operating temp, the smell will go away...... or you have a leak somewhere.
cheers!
Old Nov 2, 2006 | 02:00 PM
bboypuertoroc's Avatar
bboypuertoroc
It's prolly the gaskets... what kind are they? Every new exhaust is gonna smell like that for a little. Do you have test pipes?
Old Nov 2, 2006 | 02:04 PM
DanielW's Avatar
DanielW
no test pipes. not sure what kind of gaskets they are. whatever comes with the new stillen td i guess.
Old Nov 3, 2006 | 08:12 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Sorry guys - all wrong:
The mandrel bending technique uses a heavy grease to coat the mandrel and the ***** so they slide through the pipe, instead of ripping through the pipe.
The grease is on the inside and outside of the pipe, and it is VERY difficult to remove completely. All you are getting in that grease burning off. You'll of course smell it at a stop, because the car isn't moving and it radiates straight up into the cabin...same thing once it's parked.
Typically, it should burn off after about 5-10 miles of driving - usually within about 5 miles or so. If it wasn't cleaned well...it will take longer and even smoke a bit.
Rick
Old Nov 3, 2006 | 08:58 AM
DanielW's Avatar
DanielW
rick are you like my personal helper now man? you're giving me all kinds of answers. thanks again.
Old Nov 3, 2006 | 09:09 AM
ISMSOLUTIONS
No problem...
Old Nov 3, 2006 | 09:17 AM
chimmike's Avatar
chimmike
cheers!
wrong.
it's the mill oil in the exhaust burning off. It takes a little time. The heat shields are still there under the car when you install a new exhaust
Old Nov 3, 2006 | 01:38 PM
DanielW's Avatar
DanielW
wow thanks for the non sarcastic answer chimike
3vilbunny
Jul 18, 2017 05:10 PM
wanderingstuden
Jan 28, 2016 07:03 PM
kyin
Oct 15, 2015 05:54 AM
