3 inch exhaust
Old Nov 10, 2006 | 10:17 AM
faster than u's Avatar
faster than u
Default 3 inch exhaust
if im going for a all motor setup and nitrous will i loose power with a full 3 in axhaust like the S AAM 3" True Dual. Thanks guys
Old Nov 10, 2006 | 10:19 AM
chimmike's Avatar
chimmike
you absolutely don't need a 3" true dual exhaust on a n/a Z. 3" single is one thing, but beyond that you're in FI territory and you'd lose power for sure. Even dual 2.5" is overkill for n/a
Old Nov 10, 2006 | 10:21 AM
faster than u
will i gain with a 3 inch single
Old Nov 10, 2006 | 10:22 AM
faster than u
i like the single but is it a waist, i dont want to loose power
Old Nov 10, 2006 | 10:31 AM
first350's Avatar
first350
for NA, I'd doubt anything more than a single 3" would help
for nitrous, depending on what shot you'll be running, AAM's true dual 3" might help some...but like stated above, the dual 3" are more for FI.
*I'm NA and just ordered AAM's 3" single...low restriction and light.
-Peter
Old Nov 10, 2006 | 10:36 AM
Sam405's Avatar
Sam405
I have a AAM 3" exhaust for sell. only $500 pick up ...just shoot me a PM
Old Nov 10, 2006 | 10:45 AM
nissansource's Avatar
nissansource
Nitrous does run better on a car that has bigger exhaust. I had a 120shot zex on a nx2k with stock exhaust ran good but the Hit was 10X better with larger diam exhaust
Old Nov 10, 2006 | 10:51 AM
chimmike's Avatar
chimmike
yes, but stock exhaust on an NX2000 is like 1.4" diameter dude. Anything is better than that. Besides, you cannot compare another motor with a vq35. Apples vs. sausages.
If he runs larger than 3" low restriction single, he's going to lose torque, simple as that.
Old Nov 10, 2006 | 11:21 AM
nissansource
a Motor is a pump thats all it is how much more efficient can you make that pump. Either way yes very different bread motors 4 cyl vs 6 cyl.
Old Nov 10, 2006 | 11:31 AM
nissansource
but yes a straight 3in setup will hurt i thought he was getting some catbacksetup
Old Nov 10, 2006 | 11:36 AM
chimmike's Avatar
chimmike
obviously, but there's a point at which the engine as a pump has lost efficiency if there's too much exhaust space to fill up.
Old Nov 11, 2006 | 10:38 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
3" duals are definitely overkill for N/A man
I dont even think V10's N/A need 3" dual ...
Old Nov 11, 2006 | 10:44 PM
Amiricanmade's Avatar
Amiricanmade
*stupid Q but is the HKS Dual TI 2.5 or 3"?
Old Nov 11, 2006 | 10:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
its more like 2.25" ish (which is probably the optimal size for N/A imo)... not quite 2.5"
Old Nov 11, 2006 | 10:54 PM
Amiricanmade
thank you siihhrr.
Old Nov 12, 2006 | 04:49 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
a 3 inch true dual exhaust would be horrendously loud and ineffective on an NA cat.
All of the single exhausts out there for a Z I've ever seen are 3 inch.
The HKS true dual is twin 60mm piping
Old Nov 12, 2006 | 05:02 AM
widebody350's Avatar
widebody350
I have the AAM TD 3" exhaust on mine (which is NA) but I am going to be FI soon. With the 3" TD you lose a little torque but gain a little up top. If you are going to stay NA then go with a 3" single or 2.5" TD.
Old Nov 12, 2006 | 10:41 AM
Chineseguy's Avatar
Chineseguy
the weight you lose with a single Ti exhaust im sure is better than any TD. imo
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
