what is the different between revup plenum and non revup plenum?
Old Nov 20, 2006 | 09:50 PM
marcelz's Avatar
marcelz
Default what is the different between revup plenum and non revup plenum?
can the revup plenum install on a nonrevup motor?
Old Nov 20, 2006 | 10:23 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
sure... but you will lose midrange torque and unless you get a technosquare reflash to raise your rev limiter, you won't even get up to the RPM range where it does make torque
Old Nov 21, 2006 | 04:05 AM
tranceformer95's Avatar
tranceformer95
Doesn't the REV-UP have different cams to help it breath at higher RPM?
Old Nov 21, 2006 | 04:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I tried this, it didnt work on my car, many others have lost considerable midrange and made minimal to no gains up top. I can only think of 1 or 2 guys who say it works for them.
Old Nov 21, 2006 | 07:32 AM
97supratt's Avatar
97supratt
Revup lower plenums are just for revups. The exhaust cam phasing helps for the high rpm usage with this manifold, plus the higher redline. The loss of torque is given when you have a intake manifold that is made for high rpm peak power.
Old Nov 21, 2006 | 07:53 AM
rocks's Avatar
rocks
The non revup cams are like .376" lift, the revups are .416" from the factory.
Old Nov 21, 2006 | 08:03 AM
Yes.
Old Nov 21, 2006 | 08:52 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes.
And the odd thing is, you can make better high RPM NA gains with a spacer (or upper plenum) than by changing to the REVUP lower collector. ...And the spacer doesn't lose midrange or TQ either.
Unless you are reving to 8K+ RPMs, I wouldn't suggest using a REVUP lower plenum. It loses too much area under the curve.
Old Nov 21, 2006 | 10:57 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
yes, revup has different cams... the differences can be found on JWT's website
Old Nov 21, 2006 | 10:59 AM
marcelz's Avatar
marcelz
I have turbonetic kit,so no help at all?
Old Nov 21, 2006 | 11:02 AM
Hydrazine's Avatar
Hydrazine
Bert did exactly that when he had the TN kit on his nonrevup engine.
If I remember correctly, it lost power everywhere.
Old Nov 21, 2006 | 01:10 PM
marcelz's Avatar
marcelz
lost power everywhere.hahaha
allmycarsdie
May 13, 2016 04:38 PM
nissan1310
Oct 12, 2015 08:54 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Bigsyke
Sep 11, 2015 06:19 PM
