What is it
Old Nov 21, 2006 | 12:51 AM
Chad68's Avatar
Chad68
Default What is it
On the Nismo cat back system, it has that canister thing on the mid pipe. Is that like a resonator or what? Obvisouly it's not the Cat's so it must not have anything to do with the emissions, right? So what would happen if you by passed that canister, using just a straight pipe in it's place instead?
Would it be raspy?
Would it sound louder and or deeper?
Old Nov 21, 2006 | 04:41 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Its a resonator, it would likely sound like rapsy poo....
Old Nov 21, 2006 | 06:25 AM
z-u-later's Avatar
z-u-later
Yes, it's a resonator and you don't want to remove that or you will probably hear drone.
Old Nov 21, 2006 | 07:00 AM
Acree's Avatar
Acree
There's absolutely no reason to remove it. There is no resistance in that resonator. I'm almost absolutely sure its core is the same diameter as the rest of the exhaust, just perferated with a larger diameter pipe around it to help with rasp.
-Acree
Old Nov 22, 2006 | 08:18 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
You'll create the RASP experience of your lifetime...
Old Dec 17, 2006 | 10:51 AM
Nismospeed4life's Avatar
Nismospeed4life
Hi Alberto, I wanted to make my stock exhaust sound a bit louder. So, I was wondering of the Pros & Cons of removing the resonator? Please help.
Old Dec 17, 2006 | 11:20 AM
Acree's Avatar
Acree
I know I'm not Alberto, but this is a no. It will sound awful. If you want more sound, buy a pair of RESONATED test pipes or high flow cats.
-Acree
Old Dec 17, 2006 | 01:32 PM
Nismospeed4life
-Acree
Thanks for the reply! How much will RESONATED test pipes cost me? and, will it sound alot better than stock? And, what are the pros & cons? of this application.
Old Dec 17, 2006 | 02:06 PM
Acree's Avatar
Acree
You can pick up a set of nice used, or new cheap test pipes for around $150. Nice new ones will run around $250 or more.
Pros - a little more power, louder sound
Cons - might get a CEL, gas smell, might get a little rasp before the engine warms up
-Acree
Old Dec 17, 2006 | 03:20 PM
Nismospeed4life
-Acree
Thanks for the help.
Old Jan 12, 2007 | 06:43 AM
ZLadie2000's Avatar
ZLadie2000
-Acree
a little before engine warms up? i thought there was rasp most of the time...
