Installed my MREV2 and 5/16 MD spacer on 2006 Z!!
Old Nov 26, 2006 | 07:56 AM
IIQuickSilverII's Avatar
IIQuickSilverII
or isntall evertyhing and get an apex i a/f controller
Old Nov 26, 2006 | 09:36 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
^That works too.
Old Nov 27, 2006 | 11:59 PM
Abishop's Avatar
Abishop
Originally Posted by bugsbbunny
Maybe your strut bar is rubbing against the top of the plenum. I don't know if that's actually it, but you might want to check. Make sure there is at least 2mm of space between the bar and the plenum. I had a strange vibration when I installed mine and I found that to be the problem.
That might be it, i forgot to install the washers on the passanger side that come with the kit, thanks man!
Old Nov 28, 2006 | 10:50 PM
Hydrazine's Avatar
Hydrazine
Driver side.
But you probably only need to adjust the strut bar tension. Its an easy fix.
3vilbunny
Jul 18, 2017 05:10 PM
