Does anyone have a set of dyno sheets (before and after) showing the power to be gained from a set of high flow cats? I semi-remember seeing this before but after extensive searching I couldn't find it.
Is there anyone out there with some tangible results?
I could show you before and after dynos (sorta) but they were not done on the same day, or under identical conditions, and they were done on different dynos. So there's no point...
Nobody is going to post before and after of 1 mod, especially this mod unless its the makers of the HF cats and then the #'s will be inflated. They barely do anything, do some research on this site, Id never spend $$$ on HF cats...
The HF cats I used(kinetix) are more free flowing than stock, and quieter than TPs. I think, however, that this may be more important (add more HP) on a TT setup than NA.
Dont talk smack unless you've tried it. Mine doesnt smell, crack, sound like a fart can or throw a CEL with the proper setup.
...just reflecting what those withTP's have posted. All current and past cars without cat's (with internal combustion gas engines) smell. If your car with TP's doesn't, either shlt doesn't stink or you can't smell. We know the former isn't true.
