Upper Plenum
Old Jan 17, 2007 | 12:51 PM
VO...'s Avatar
VO...
Administrator
Wired, since we got you on here. Are the torque specs I listed correct, to your knowledge? 61 inch lbs.
Old Jan 17, 2007 | 02:48 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
According to the service manual, SOME of the bolts around the plenum are right around 61 inch-lbs, other bolts on the plenum are 9-10 ft-lbs. So that converts to about 108-120 inch-lbs.
I would play it safe and follow the instructions you have if they tell you to use 61 inch-lbs for everything. If you have leaks (which seems doubtful) you can double check torque specs.
Don't use any goo. Using a new gasket could make the job a bit easier, although it's generally not required. Unless the old gasket is damaged in some way.
You're not going to be creating any serious high pressure or high vacuum seals, so the original gaskets should be adequate for preventing leaks at low vacuum.
Old Jan 17, 2007 | 02:59 PM
VO...'s Avatar
VO...
Administrator
Thanks for the info. I might just stop by the dealership and pick up a new gasket to be on the safe side. It won't hurt.
Old Jan 17, 2007 | 07:56 PM
first350's Avatar
first350
IIRC they want you to step up the torque slowly...torque everything to 30, then 60, then 90 in-lbs.
*since we're on the subject of plenums...here's a preliminary shot of my modified OE plenum (it still needs a few more coats of paint and elbow grease before it's finished...I can't wait to get this installed)
Old Jan 17, 2007 | 08:05 PM
__jb's Avatar
__jb
Z + Rear Seat
Wow, no center bolts at all... I've never seen anybody do that before... What did you do, weld them up?
Old Jan 18, 2007 | 02:17 AM
fabcas311's Avatar
fabcas311
Default help question.....
does the 5/16 isothermal plenum sapcer fits on the 2006 z?..wat r the pro and cons?...whatelse do i need after installing the spacer?wats the nxt mod?thanks for your help......
Old Jan 18, 2007 | 03:24 AM
Eazzy's Avatar
Eazzy
What the instructions do not include is whether or not I'll need a new gasket or any type of gasket sealant goo, when installing the new plenum. Anyone care to shed some light?
Val
If u dont screw it up --the top perimeter Gasket is reusable ---But as a precaution ( whether new or not ) I use CRC Spray Sealant and let it tack just before the install and torque
Old Jan 18, 2007 | 05:52 AM
first350's Avatar
first350
I used JB weld ... I did lots of research on welding those holes, but it sounded like a big pain - 1) cast alimunim alloy is hard to weld with b/c different alloys will melt at different temps...so you need to try to match the alloys if possible. 2) since it's such a big peice of material, getting the right temp is even harder (heat is dissapated quickly)
*when it's done, I'll create a new post w/ pics through the whole process.
-Peter
Old Jan 18, 2007 | 09:43 AM
VO...'s Avatar
VO...
Administrator
That's a good idea too.
Old Jan 18, 2007 | 10:45 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
the only reason I say that is, I know if the old gasket is deformed or has any kinks, it is not the easiest thing to reinstall it...
Old Jan 18, 2007 | 02:07 PM
VO...'s Avatar
VO...
Administrator
I called the dealership today. None in stock. 5 business day turn around. I need it by Saturday. The local auto parts stores don't carry them either. Looks like I'll have to be real careful with the original gasket. The car has really low mileage on it. Everything should still intact.
I gotta pic up a small torque wrench too. I don't think my old one is good anymore. It's seen better days.
VO(has his fingers crossed)
Old Jan 22, 2007 | 07:26 AM
VO...'s Avatar
VO...
Administrator
I completed the install this weekend. Was pretty easy. Had to pick up a new Craftsman toraue wrench @ Sears on Saturday morning.
A buddy came over and we installed it in about 3hrs. Of course this included beer breaks in between.
Only difficult part I found were the little retaining clips that hold the hoses in place. Sometimes it was hard getting my hand into little crevices, inorder to remove the clips. It's not impossible, just time consuming. While I had everything off I took the time to spray some car cleaner in the throttle body and clean off some of the built up carb deposts & dirt that accumilate over time.
I had no problems with the gasket. In fact, it didn't even come off the engine block. It was a thin, hard, black metal gasket that is actually attached the the engine block with some type of metal plate...
Everything looks great. No leaks. Torqued everything to 61 inch lbs using the diagram I snatched up from another website. I torqued the bolts in three sets, like someone mentioned earlier: 20 inch, 40 inch, then 61 inch lbs.
Thanks for all the info guys. I'll post pics tomorrow.
(attached is the bolt tightening sequence)
Old Jan 22, 2007 | 08:16 AM
first350's Avatar
first350
glad to hear everything went well!
Old Jan 23, 2007 | 12:52 PM
VO...'s Avatar
VO...
Administrator
as promised...
Old Jan 23, 2007 | 01:08 PM
first350's Avatar
first350
as promised...
nice!!! love the look w/ painted engine cover!
Old Jan 23, 2007 | 01:32 PM
VO...'s Avatar
VO...
Administrator
thanks
Here's the rest of the engine.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
_koubie_
Sep 20, 2015 06:34 PM
