1/2 Plenum Spacer
Old Jan 21, 2007 | 06:36 PM
Wraeththu's Avatar
Wraeththu
Default 1/2 Plenum Spacer
Hello,
This being my first post, i hope i dont get flamed for it.
I wanted to get the 1/2 plenum spacer but know that it wont allow the hood to close with the stock strut brace on, but is there any after market strut brace that will fit? If not ill just go with the 5/16th spacer.
Thanks
Old Jan 21, 2007 | 06:40 PM
Eazzy's Avatar
Eazzy
Go with the MD 5/16 -----Forget the 1/2
Old Jan 21, 2007 | 08:17 PM
first350's Avatar
first350
1/2" is too big. AAM's angled plenum spacer or MD's 3/8" spacer will fit fine.
Old Jan 21, 2007 | 08:21 PM
DJMatrix1067's Avatar
DJMatrix1067
5/16's FTW
Old Jan 22, 2007 | 04:45 AM
Welcome. Look at photos of strut braces. Some are designed to fit in front of the motor. With this type of brace, you can install a 6-inch spacer if you want.
Old Jan 22, 2007 | 05:01 AM
meaj82's Avatar
meaj82
What he said. The Stillen strut bar comes to mind.
Old Jan 22, 2007 | 05:54 AM
13SECZ's Avatar
13SECZ
Is there much of an advantage going with the 1/2 ?....any hp gains vs. the 5/16 or 3/8....?
Old Jan 22, 2007 | 07:59 AM
cturnbull802's Avatar
cturnbull802
nope. they claim 1 to 2 hp diffrence which is well in check of dyno inaccuracy
Old Jan 22, 2007 | 09:06 AM
meaj82's Avatar
meaj82
I think all there is a slightly different engine note. Maybe +/- 1-2 hp if anyhing and I think it happens near redline.
Old Jan 22, 2007 | 09:10 AM
Reality350's Avatar
Reality350
OP, if you have a rev-up motor, get the MREV 2 and the 5/16 spacer.
Cheers,
R
Old Jan 22, 2007 | 09:41 AM
tropicalypso's Avatar
tropicalypso
ROFL
Old Jan 23, 2007 | 07:54 AM
thilak's Avatar
thilak
I looked at these Mrev and 5/16", under the spacer the websites has 2 other option one is basic, one is iso thermal, the other one is copper iso thermal.
Do these make different power? Im planning to go wtih the basic one cause its alot cheaper, any info helps. Thank u.
Old Jan 23, 2007 | 01:01 PM
Eazzy's Avatar
Eazzy
In a colder climate like ur in --go with the valve assy, In the warmer/Hotter climates use the Copper TB spacer for the re route of coolant. Call Motordyne and talk to them
hulkout
Apr 28, 2017 09:00 PM
Mattg350z
Oct 2, 2015 06:51 AM
