Borla vs Nismo exhaust..
Old Aug 15, 2007 | 12:02 AM
  #61
supra crazy's Avatar
supra crazy
Originally Posted by iceagetlc
I had a horrible experience with my borla.
The clamp system is outdated, and any removal of the pipes after being sealed makes it impossible to retain the same seal when re-attached, if you can get them apart.
The H-pipe is hilarious. You're only option is to weld it, and even when I did, my new test pipes put seperating pressure on the pipes and eventually cracked the seal. (not isolated problem)
The muffler hangars vibrate from contact with the rods and had to be shaved. (not isolated problem)
It's overall ugly, both underneath and from the back. Tips are the nicest thing.
Sound is not different enough from stock to be worth the $$ or effort, and any power gains weren't noticed.
Mind you I did all the work myself so I'm not going off what any shop said or what I "thought" was the problem. I was glad to get rid of it.
I had the same problem with my borla The H pipe would leak so I had it welded and having it welded was a bad idea that made the whole exhaust rigid.so th engine torque ended up cracking the H pipe...I have since had flex pipes welded in the Y pipe and haven't had a problem since. I personally love the Borla sound a lot less rasp with TP then all the exhaust out for the Z..
Old Aug 15, 2007 | 12:05 AM
  #62
zcon's Avatar
zcon
Default Fi
Go Fast intentions supra crazy knows he is intimidated
Old Aug 22, 2007 | 06:06 AM
  #63
03aeroZ's Avatar
03aeroZ
anyone have problems with the fast intentions not having flex points? seems like it would crack welds like every other exhaust without flex points does.
JjL
East Canada
Jun 12, 2019 03:04 AM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
