MREV2 and Spacer!
Old Mar 17, 2007 | 06:32 AM
Floyds_racing's Avatar
Floyds_racing
Default MREV2 and Spacer!
I just installed the MREV and a Skunk2 spacer on a 06 350Z and the strut bar touch the upper Plenum. will it damage the upper if it touchs it?
Old Mar 17, 2007 | 06:45 AM
Fletch69z's Avatar
Fletch69z
It may scratch it and it's not the best thing for the plenum for sure. Did you receive hood spacers and strut bar spacers with your plenum spacer? Ask Motordyne if they will send you some or if they will give you the sizes you need and you can get them for cheap at a hard ware store. With my 3/8ths in. plenum spacer I got spacers so that it wouldn't rub.
Old Mar 17, 2007 | 06:47 AM
Floyds_racing
but wont that thru the hood lines off!
Old Mar 17, 2007 | 06:49 AM
Floyds_racing
That looks like shyt no offense!
Old Mar 17, 2007 | 07:18 AM
bobS's Avatar
bobS
Thats not a serious pic is it? Why would anyone do that to their hood.
Old Mar 17, 2007 | 07:44 AM
Floyds_racing
he did that to clear the MREV and Spacer! and to keep the factory strut bar!
Old Mar 17, 2007 | 07:47 AM
Theatrix's Avatar
Theatrix
Professional
If the pic is accurate, then you need a lower profile strut bar. How thick is the skunk spacer? It has to be more than 5/16th's because it shouldn't raise up that high if it is.
Old Mar 17, 2007 | 08:05 AM
Floyds_racing
its 5/8" and who makes a lower profiled one? and that pic is of Fletch's car!
Old Mar 17, 2007 | 08:09 AM
farobaba's Avatar
farobaba
lol@who makes one, SEARCH! it's all over the place. Motordyne is good, so is AAM
Old Mar 17, 2007 | 08:29 AM
Floyds_racing
im talking about a strut bar and a found the only one that will fit!!!
Old Mar 17, 2007 | 08:36 AM
jdo's Avatar
jdo
why do u use so many exclamation points?!!! and I can barely understand your posts because of typos!!! I think I'm losing my mind!!! you need an aftermarket strut bar!!! only with the 5/16th spacer can you use the factory strut bar!!! I hope this helps!!!!!!!!!!!!!!!!!!!!!!
Old Mar 17, 2007 | 08:54 AM
Floyds_racing
I ALREADY FIGURED THAT OUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 17, 2007 | 09:05 AM
Abishop's Avatar
Abishop
alright, ill put this thread to sleep........Ok, after installing your MREV and spacer. Once its time to put on your strut bar, there should be 8 thick spacers and 4 1/16-1/8th zinc washers. Install the thick spacers under the strut bar and the zinc washers under the passenger side of the strut bar. To make this clear there should be thick spacers and zinc washers under the passangerside of your strut bar. This will make your strut bar fit over the plenum without rubbing.
The reason people do that to their hoods if for venting purposes only. Do not touch your hood with anything motordyne sends you. PM me if you have any more questions.
Old Mar 17, 2007 | 09:13 AM
Abishop's Avatar
Abishop
Unhappy
Old Mar 17, 2007 | 09:15 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I've developed several different spacers for applications under the hood but I never designed them for a 5/8" spacer. Thats too big for what I have here.
Maybe I can put something together but there aren't many people who will try to fit a strut bar over a Skunk spacer.
The APS strut bar would be a more practical solution.
Old Mar 17, 2007 | 01:04 PM
Floyds_racing
I have a few spacers that I can install on the passenger side! I will see what it does.
Old Mar 17, 2007 | 01:05 PM
Floyds_racing
And it didnt come with washers and/or spacers
Old Mar 18, 2007 | 10:36 AM
davidf's Avatar
davidf
You also want to remember the engine will move under torque.
Old Mar 18, 2007 | 10:40 AM
Jay'Z's Avatar
Jay'Z
+1
Old Mar 18, 2007 | 04:29 PM
Floyds_racing
yeah I just took it off
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
