did i do somehing wrong?
Old Mar 23, 2007 | 09:01 AM
03aeroZ's Avatar
03aeroZ
Default did i do somehing wrong?
Just installed the motordyne 5/16'' spacer, now when i start the car, it feels a bit rough....is this normal? i also put a grounding kit on...but took that off and same feeling. just didn't know if the spacer made the engine feel just a little rough. fast help needed!!
Old Mar 23, 2007 | 09:02 AM
THE TECH's Avatar
THE TECH
Hard to say with that vague description.
Sean's Avatar
Sean
reset ECU?
Old Mar 23, 2007 | 09:05 AM
03aeroZ's Avatar
03aeroZ
i reset ecu..did the whole list. there just seems to be more of a vibration in the wheel (at idle) than i remember before. nothing sounds different (no leaks, no grinding). does have a different exhaust note. checked all the lines, cel isn't on, all bolts are tight.....did anyone else notice a small difference in how the car felt?
Old Mar 23, 2007 | 09:09 AM
h8bumps's Avatar
h8bumps
Your strut bar is probably touching the plenum. This will transmit vibrations.
Adjust your strut bar so it doesn't contact the plenum. Also, check when the engine is hot -- there is less clearance after all components have thermally expanded.
Old Mar 23, 2007 | 09:10 AM
MUZZY's Avatar
MUZZY
did u install the spacers?
THE TECH's Avatar
THE TECH
Good idea.
Old Mar 23, 2007 | 09:35 AM
z-u-later's Avatar
z-u-later
The strut bar bolts may also be loose . . .
Old Mar 23, 2007 | 09:49 AM
03aeroZ's Avatar
03aeroZ
strut bar is a greddy bar...can't adjust. all the bolts are at 24ft/lbs. i can add the additional spacers...will try this. thanks alot...thought i just forked myself!!
Old Mar 23, 2007 | 10:22 AM
03aeroZ's Avatar
03aeroZ
MUCH better...that did the trick. thanks alot
Old Mar 24, 2007 | 10:30 AM
first350's Avatar
first350
since you have the greddy strut bar , you might want to check that it's not rubbing on the hood now...I have JIC's strut and AAM's spacer...it took a few adjustments to get it just right.
Old Mar 25, 2007 | 05:42 PM
03aeroZ's Avatar
03aeroZ
well i added the spacer, much better....until the car warms up or under load when warmed up....so. I think i may need to add some more spacer washers...but on what side and how much room under the hood do i have to play with? anyone have any ideas?
Old Mar 25, 2007 | 06:08 PM
first350's Avatar
first350
that sounds right...when the engine is under load, it rotates a bit - just keep adding small washers/spacers until the strut bar doesn't rub under engine load.
Old Mar 25, 2007 | 08:01 PM
03aeroZ's Avatar
03aeroZ
anyone know how much distance is needed between the plenum and strut bar to prevent this? i am rocking out with 1/4'' right now....lol...i bet the engine rotates a bit more than this! got any ideas?
Old Mar 26, 2007 | 05:22 PM
03aeroZ's Avatar
03aeroZ
nevermind...thanks for all the help guys....added another small spacer (had sht loads of rub under the strut brace) and removed the little black cushions on the hood.....all is good. no hood rub, no brace/plenum rub even under load. all is good. thanks again.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
