High Flow SMOG Legal Cats
Old Apr 1, 2007 | 04:34 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
Default High Flow SMOG Legal Cats
I am looking to buy some cats that are legal in california and have a carb number. I know kinetix has some but anyone know any other companies who offer a similar product?
Old Apr 1, 2007 | 05:09 AM
CESAROTORRES's Avatar
CESAROTORRES
Here is all the one that are available, I like the NISMO and Power Enterprise.
http://HFcats.notlong.com
Cesar
Old Apr 1, 2007 | 07:20 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
thank you
Old Apr 1, 2007 | 07:29 AM
gt3's Avatar
gt3
Technnically none of them are legal in Cali...you may pass the smog portion but not the visual.
Old Apr 1, 2007 | 07:33 AM
CESAROTORRES
WRONG, The he will with pass with the NISMO!
Cesar
Old Apr 1, 2007 | 07:45 AM
Armitage's Avatar
Armitage
Originally Posted by CESAROTORRES
WRONG you will with the NISMO!
Cesar
AFAIK, it is illegal at any point to replace OEM cats with another brand/type of cat unless it is OEM.
Old Apr 1, 2007 | 07:49 AM
MR_X's Avatar
MR_X
You can consider NISMO to be OEM
Old Apr 1, 2007 | 10:10 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
nismos are really expensive no?
Old Apr 1, 2007 | 10:44 AM
Z MANIA's Avatar
Z MANIA
psychedelic one
** Please check local laws regarding catalytic converters. These pipes have passed visuals and sniffer tests in CA (the strictest state on emissions) but they do not have a CARB number associated with them. **
NOTE: Replacing the OEM cats with test pipes, aftermarket high flow cats, or modifications of any kind to the OEM cats is ILLEGAL!
2 notes that I found using the link above. I believe that even if you damage your cats, in California, you must replace them with exactly the same cats. Many Z owners here have modified with test pipes or high flow cats, and I do not think that this is a "fix it" ticket any more.
Old Apr 2, 2007 | 08:38 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
OK - so here's the real skinny all -
In Cali - you need OBDII certified cats - and the only ones available are your OEM CATS.
CARB numbers are great for Cali - for things like headers, but not for CATS.
Keep in mind - you may pass a sniff test or visual, if the tech doesn't look at them at all.
That's the fact jack!
Rick
Old Apr 2, 2007 | 09:13 AM
jonnylaw's Avatar
jonnylaw
Also--Federal Law--I don't think you are allowed to swap out cat's under federal law until 50k, if they are working.
Old Apr 2, 2007 | 09:16 AM
ISMSOLUTIONS
You can swap out anything as long as it is relaced with approved and certified products, of which in this case, there are none.
Rick
Old Apr 2, 2007 | 11:05 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Rick
+1 on all
Old Apr 2, 2007 | 12:53 PM
MR_X's Avatar
MR_X
I don't think NISMO cats will be a problem. They look OEM anyways.
Old Apr 2, 2007 | 01:59 PM
THE TECH's Avatar
THE TECH
Originally Posted by Wired 24/7
+1 on all
+2
No such thing as a SMOG legal cat besides the OEM. Not even the Nismo ones are legal.
Old Apr 2, 2007 | 03:11 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
so do kinetix and are probably cheaper
Old Apr 4, 2007 | 10:43 PM
SS21CA's Avatar
SS21CA
I passed with Random Tech hi-flow cats. There are certain restrictions to changing your cats in ca but its safer and better for environment if you have cats as apposed to straight pipes. No check engine light either.
Old Apr 4, 2007 | 10:50 PM
extreme4377's Avatar
extreme4377
Fast Intention HFC or TP. Who cares about passing smog tests. Just swap the cats out when the time comes
Old Apr 5, 2007 | 08:57 PM
Chad68's Avatar
Chad68
So why are HFC's illigal in CA if they pass the sniff test and asuming they meet sound DB levels?
Never made sense if they pass the sniffer why are they sooooooooooooo/illigal bad to use.
Old Apr 5, 2007 | 09:09 PM
jonnylaw's Avatar
jonnylaw
Nismo Cats Are Discontinued
