Crack in plenum spacer
Old Apr 9, 2007 | 04:49 PM
moog's Avatar
moog
Default Crack in plenum spacer
Do you guys think this will affect performance? It's one of the smaller holes in the spacer...not sure if it will cause an air leak. The gasket it came w/ doesn't cover that particular hole.
Old Apr 9, 2007 | 07:49 PM
first350's Avatar
first350
as long as the crack isn't through the interior portion, it should seal fine...do you know how it cracked? It's not a stressed component - maybe someone dropped it.
-Peter
Old Apr 9, 2007 | 07:52 PM
Mazinger Z's Avatar
Mazinger Z
Are you sure that's a crack? Because I think the way MD made it, there should be some type of "crack" there. I looked at mine when I first got it and that's how I remembered it looking
Old Apr 9, 2007 | 08:15 PM
striker27's Avatar
striker27
You are screwed I will take it off your hands for 10 bucks and will even pay the shipping!!!!!!
Old Apr 9, 2007 | 08:26 PM
Mike Wazowski's Avatar
Mike Wazowski
that is fine.
if in fact that is the only crack
Old Apr 9, 2007 | 08:27 PM
THE TECH's Avatar
THE TECH
If it is truly cracked, you can have it welded or use some type of JB Weld to fix it. It could also be a casting mark (I cannot tell from the pics).
Old Apr 10, 2007 | 06:03 AM
first350's Avatar
first350
MD makes their spacers from 2 peices that fit together; the location where the 2 peices fit together is very smooth and almost invisible...the pics he has looks like a real crack
Old Apr 10, 2007 | 08:00 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Hey guys that aint no MD spacer!
Thats a Skunk2.
Old Apr 10, 2007 | 08:04 AM
THE TECH's Avatar
THE TECH
Thats a Skunk2.
You sure about that? The Skunk is composite and that looks clearly like metal.
Old Apr 10, 2007 | 08:23 AM
Hydrazine's Avatar
Hydrazine
Yes. I know what my own design looks like.
That's 100% Skunk.
Old Apr 10, 2007 | 08:37 AM
THE TECH's Avatar
THE TECH
That's 100% Skunk.
Oh, I'm not saying that it's def yours, just saying it looks like a metal piece which would not be consistent with a Skunk product.
Old Apr 10, 2007 | 08:42 AM
Hydrazine's Avatar
Hydrazine
It looks like a cell phone picture using a nearby lamp as a light source. (with the usual cellphone picture distortion)
I think the lamp is adding glare that makes it look like metal.
Besides, look at the cracked tab... There is no such tab on the MD spacer.
http://motordyneengineering.com/imag...spacer$215.JPG
Old Apr 10, 2007 | 03:17 PM
moog's Avatar
moog
It's a Skunk2 spacer.
Old Apr 10, 2007 | 03:26 PM
Sean's Avatar
Sean
is it made of phenolic material? (like fake wood) I would superglue it.
Twenty4
Jan 17, 2016 01:20 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
