5/16 Spacer
Old Apr 18, 2007 | 06:39 AM
joe3906's Avatar
joe3906
Default 5/16 Spacer
How hard is it to install the 5/16 spacer in an 06.
I tried the search button, but "I" could not find a difinitive answer, nor could I get one from the motordine vendor. I'm thinking of buying one, and want to know if it takes more than a shady tree mechanic ability to install one. If done by a shop, about how much would it cost. All flames graciously accepted.
Thanks,
Joe B.
Old Apr 18, 2007 | 09:11 AM
h8bumps's Avatar
h8bumps
I don't think the '06 is much different from and '05 (since the MREV2 will fit either engine). It's easy, and the instructions that Motordyne includes with their spacer guide you through all the steps.
Old Apr 18, 2007 | 09:17 AM
SamaeLZ33's Avatar
SamaeLZ33
it took me about an hour to do mine, 1 1/2 if you count the cigarette brake test drive then re-torque of the bolts.
Old Apr 18, 2007 | 09:53 AM
joe3906's Avatar
joe3906
Thanks!
Old Apr 18, 2007 | 06:27 PM
The install is straight forward. Members tend to get crazy with wenches, and break bolts.
Old Apr 18, 2007 | 06:43 PM
gqong's Avatar
gqong
just read the instructions over a couple of times and make sure you know exactly what you are doing its a pretty straightforward install..not many ppl have problems! good luck
Old Apr 18, 2007 | 06:57 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Thanks,
Joe B.
Here you go:
THIS QUESTION IS ASKED AT LEAST ONCE A WEEK. HOW COULD YOU NOT FIND IT? YOU FAIL AT SEARCHING
That is all
Old Apr 19, 2007 | 01:56 PM
theanswer0127's Avatar
theanswer0127
how much does the 5/16 spacer alone (without mrev2) help with revup engines?
Old Apr 19, 2007 | 01:58 PM
zstreet86's Avatar
zstreet86
motordyne has the full installation instructions on their website
Old Apr 19, 2007 | 03:10 PM
xav_350z's Avatar
xav_350z
dude it took me 30 min!
very simple to install...
good luck!
Old Apr 19, 2007 | 05:12 PM
jondimellow's Avatar
jondimellow
Originally Posted by Wired 24/7
Here you go:
That is all
which one is better: pop charger or injen cai?
ps
rsx is faster
Old Apr 19, 2007 | 06:43 PM
joe3906's Avatar
joe3906
Thanks; Now I feel a lot better about ordering the spacer. With the popcharger and spacer installed, what would be the next most sensible up-grade? Flame away.
Old Apr 19, 2007 | 11:55 PM
Cloud's Avatar
Cloud
It's not that hard, there's lots of info if you search for it. Just make sure you don't break any bolts.
Old Apr 20, 2007 | 07:15 AM
JMS71585's Avatar
JMS71585
Go with some resonated test pipes or some high flow cats.
You could go with headers, but that install is harder and more time consuming than a spacer install.
Old Apr 20, 2007 | 10:41 AM
Reality350's Avatar
Reality350
Add the MREV2.
Good luck!
Old Apr 20, 2007 | 02:50 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
ps
rsx is faster
Old Apr 21, 2007 | 08:11 AM
OH6 G35's Avatar
OH6 G35
Has anyone had any "trouble" installing the 6 spacers (in the top plenum) ??
_koubie_
Sep 20, 2015 06:34 PM
