yet another rasp question please help
Old Apr 26, 2007 | 04:12 PM
ldawg32's Avatar
ldawg32
Default yet another rasp question please help
i have searched for a while now and found nothing to answer my exact question. I have a woosh sound while driving around 2.5-3k rpm. it sounds like an air leak but i had it idling on a lift and no puttering air whatsover. will you hear rasp while rpms are on there way up as well as on there way down. when i rev it up and it comes back down i hear the rasp. im fine with that doesnt bother me too much. the question is should i hear rasp while im acclerating? it sounds like an air leak but i dont believe its leaking. should i put it on a lift and rev it to find air leak? or is checking it ad idle sufficient enough?
Old Apr 26, 2007 | 05:53 PM
first350's Avatar
first350
yep, it's rasp! when I slow down and am around ppl, I take it out of gear so the rasp doesn't last as long.
Old Apr 27, 2007 | 07:13 AM
ldawg32's Avatar
ldawg32
yeah thnx man i thought it was. can rasp be defined also as a whisp of air. like i said kind of like an air leak but its not an aor leak?
Old Apr 27, 2007 | 10:49 AM
angelzhope720's Avatar
angelzhope720
wow just installed my helix test pipes + kinetix y pipe today. it is so raspy and smelly lol but i like it
Old Apr 27, 2007 | 01:40 PM
ldawg32's Avatar
ldawg32
yeah about the smell FTW! i love that smell. yeah i went from hi flow cats to test pipes and the smell is awesome.
now you need y pipe back exhaust and your all set
Old Apr 27, 2007 | 05:03 PM
terrasmak's Avatar
Why do people care so much about rasp , it happens with performance parts .
Old Apr 27, 2007 | 05:48 PM
dedmoonstears's Avatar
dedmoonstears
you sure it doesnt sound like a zoom..
Old Apr 27, 2007 | 08:38 PM
ldawg32's Avatar
ldawg32
i dont care about rasp just want to know if it possibly an air leak or not.
Old Apr 27, 2007 | 09:24 PM
bacalhau16's Avatar
bacalhau16
If you went underneath, and heard nothing, then I would stop worrying about it! Sounds like your all good to go!
Old Apr 27, 2007 | 09:33 PM
ldawg32's Avatar
ldawg32
yeah i hope so. lol
Old Apr 28, 2007 | 09:52 PM
iceagetlc's Avatar
iceagetlc
You are pretty much dead on describing an air leak. It can also be described as a wet sputtering that is buzzier as you drive.
Rasp in a sound caused between 3 and 4k rpms at a little past half throttle with test pipes.
An air leak sound happens at all times, even coasting or sitting and revving to low rpms.
You won't be able to tell by being underneath the car, as this noise can be generated by even the smallest gap in a relief cut that's even under a clamp, or any space between two flanges large enough to slide a fingernail in.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
