Differences betweed Injen exhausts (old and new)
Old May 10, 2007 | 02:03 AM
Skorch's Avatar
Skorch
Default Differences betweed Injen exhausts (old and new)
I just bought a used Injen SES exhaust from a local guy here in AZ. I got it for what I thought was a pretty decent deal - $320. The thing is, from what I've researched it happens to be the very first version of the Injen exhaust ever made. It's a true dual with angled tips. It's only 4 pieces (2 for each side), which is different from the newer versions that Injen has released - the newer ones have more pieces. If someone has some knowledge about this exhaust, I'd love to hear from you. How does it compare to the new one? Were there any known problems with it? So far the fitment is so so - the left tip is slightly brusing against my bumper and I don't know how to adjust it. It sounds very deep on my '07 and I like the tone. Is this exhaust obsolete and I got pretty much screwed on the deal or will it be fine? I tried searching this topic, but I can't seem to gather anything that would answer my questions straightforward. Thanks alot in advance for your help.
Old May 10, 2007 | 02:36 AM
MikeEwithTheZ's Avatar
MikeEwithTheZ
That one you have to watch your bumper because how it exits, also the new ones have a different muffler style, and also an H-pipe...thats all i know im not an expert, you didn't get ripped off don't worry
Old May 10, 2007 | 05:03 AM
Take a closer look. The ses1985c is 6 pieces.
Old May 10, 2007 | 05:09 AM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Old May 10, 2007 | 05:48 AM
Skorch's Avatar
Skorch
Thanks for the pics guys - I've already seem what the new exhaust looks like. I was asking more about quality issues, performance differences and general info about what to expect from my old-style exhaust.
Old May 10, 2007 | 05:59 AM
tranceformer95's Avatar
tranceformer95
IIRC, Injen increased the ID of part of the piping on the new Track Ti version?
Old May 10, 2007 | 07:01 AM
Jim@Showstoppers
70mm
Have any pictures of the "older" style?
Old May 10, 2007 | 07:15 AM
davids's Avatar
davids
F U StuLax18
Just to note this is one of the nicest sounding exhausts you can get.
Old May 10, 2007 | 08:20 AM
IIQuickSilverII's Avatar
IIQuickSilverII
+1
try to get Injecn track one
if not get the regular INjen SES
Fi wise the regular ses is thin but i have seen it good to 430whp, the new track one i have seen it good on 550whp
Old May 10, 2007 | 08:28 AM
Jim@Showstoppers
I've got the tracks in stock for $899 shipped.
https://my350z.com/forum/showthread....ighlight=injen
Old May 10, 2007 | 08:34 AM
Jim@Showstoppers
Hey OP, does this look like yours
Old May 10, 2007 | 09:37 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I think from the description the OP has the first version like the ones pictured here. The biggest difference besides the amount of sections is that the earlier system has removable silencers where as the one posted directly above has them welded into the back boxes.
As far as rubbing, first try loosening up all the connections and moving the back box around to see if you can get it where you want it, in the end you may need to bend the hanger so get it to sit where you want.
Chris
Attached Thumbnails Differences betweed Injen exhausts (old and new)-350zmotorsports.jpg
Old May 10, 2007 | 03:01 PM
Skorch's Avatar
Skorch
Chris
Thank you, this is the exact exhaust I have. I guess it's time to bend the hanger.
Old May 10, 2007 | 03:09 PM
hwcustoms's Avatar
hwcustoms
I love my Injen SES. High quality and very low mild tone that sounds perfect.
Old May 10, 2007 | 04:03 PM
Skorch's Avatar
Skorch
Do you have one of the newer models of that exhaust?
Old May 10, 2007 | 08:20 PM
drewb612's Avatar
drewb612
I have this exhaust, what do you want to know? It sounds great, I have a welded in magnaflow x-pipe on mine
Old May 11, 2007 | 01:11 AM
Skorch's Avatar
Skorch
Cool, that's the same one I have too. Where did you get a Magnaflow x-pipe for it? Was it pretty expensive to get it done? What would an x-pipe do vs having two separate pipes? Also, I noticed my exhaust has an extra stud on it for a hanger on the driver's side, but there is no hanger there under the car. Is this normal? The passenger side also has two, but both of those have hangers they go into.
Old May 11, 2007 | 09:25 AM
drewb612's Avatar
drewb612
I actually bought it with the pipe there already, i think it would run about $100. It is supposed to get rid of any rasp and make it sound a bit better, this would def. be an improvement as well for someone running this exhaust with test pipes. I had the same hanger problem, not sure what to do. I installed the exhaust but the tips are maybe 95% perfect. For me I didnt have a bracket for a hanger on the passenger side. I am just going to take it to a shop and have the line them up and hang it properly for $40 or w.e.
Old May 11, 2007 | 02:43 PM
Skorch's Avatar
Skorch
Thanks alot for the info! I guess I better take mine to the shop as well to get lined up. Maybe I'll mess with the driver's side hanger first to see if I can bend it and line it up myself. Thanks again.
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
350z82
Oct 1, 2015 06:25 PM
