Help understanding the concept of "Bottle Neck"
Old May 19, 2007 | 09:04 AM
jmr0311's Avatar
jmr0311
Default Help understanding the concept of "Bottle Neck"
I want to buy an aftermarket Y pipe but I need some help from you guys. I have Alphawerks headers which I'm not to sure but I think the outlet pipe is like between 2 - 2.25 inch and then I just bought a new Greddy Ti-C single exhaust that the mid pipe is 2.75 inch. I heard that when you are matching exhaust parts that you don't want to mismatch diameters because you create a bottle neck effect which takes away performance and worsens the sound. Guys, is this true or I'm just full of sh**. The majority of the Y pipes out there would not work for me because they are or 2.25 > 3 " or 2.5 > 3 " which creates that bottle neck effect on my car. Any comments are very appreciated.
Old May 19, 2007 | 09:35 AM
I would prefer to go from a 50 mm inner diameter pipe to 60 or 70 mm. Not the other way around. There is a adverse effect on exhaust volume and velocity. Whether you consider the effect trivial of significant is debatable.
Old May 19, 2007 | 10:36 AM
plumpzz's Avatar
plumpzz
The effects are debatable as davidv says, as long as your N/A. When you're NA, the design, not size, matters. For example, a poorly designed (bad placement of the joint) Y pipe will obviously make less power than an optimally designed X pipe regardless of piping diamater, as long as its not too small or too large. 2.5'' dual or 3'' single is probably best for this car, based on testing different exhausts.
Old May 19, 2007 | 12:27 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
? the size matters just as much as the design
Old May 20, 2007 | 12:11 PM
plumpzz's Avatar
plumpzz
I said after a certain size. 1.85'' is obviously too small even for treu dual. For single anywhere between 2.5 and 3.5 is fine and for true dual anywhere between 2.0 and 2.5 is fine. I think size has less of an effect than design.
Old May 21, 2007 | 12:24 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think it's clear. Matching diameters perfectly is a good thing. If you cannot for some reason, you should go smaller to larger, not larger to smaller.
Obadabot
Jun 18, 2023 11:31 PM
burglapfd
Dec 6, 2020 01:04 PM
Vigman
Nov 17, 2015 04:34 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
