Crazy idea! So crazy it just might (not) WORK!
Old May 22, 2007 | 08:33 AM
scratch137's Avatar
scratch137
Default Crazy idea! So crazy it just might (not) WORK!
Ok well i just thought about something and i am by no means a car expert, but am by no mean a moron so dont judge me off this one moronic comment . So i was thinking to my self, what if you can take piping from the exhaust striaght off the headers (maybe redesign the headers alittle) and have those pipes connect to a intercooler like a turbo, then super chill the air w/ one of those Smax intercooler things a few posts down or something similar, then feed it back into the intake manifold. I would create much more air flow like raming in alot of air, similar to a turbo except well...not. But then i started thinking well that can work because all that would just be a closed circuit and would build up hella pressure, so something like a valve, omg BOV?!?! that would let some exhaust out and some still into the intake. I figure it will definently provide more air then just an intake, and the pressure would help, but its just alot of hot air. So if you can cool it and somehow make it so some air can escape, maybe it would be ok? I mean hell, air coming from a turbo is probably alot hotter before it goes through the intercooler then just normal exhaust air. Any ideas?
If it is just that retarded then let me know, but also maybe explain why, or how it could be corrected. I dont really plan on doing this, but i just wonder "what if". I like to know the randomness and what not
Old May 22, 2007 | 08:36 AM
kostat26's Avatar
kostat26
wow, i predict flaming in ur future
CTU-Z's Avatar
CTU-Z
Interesting idea, my only concern is; what about the "dirty" exhaust? How would you keep it clean?
Old May 22, 2007 | 08:37 AM
Fluid1's Avatar
Fluid1
So you want a turbo setup, minus the turbo?
iceagetlc's Avatar
iceagetlc
You're gonna get flamed but I'm the type of person that loves speculating and curiosity and testing weird things, with that wild "what if" imagination.
But in the end I think the air would be too hot to cool fast enough... You're talking about air having to immediately exit and re-enter....
Old May 22, 2007 | 08:38 AM
LeMans 05's Avatar
LeMans 05
Wow. Ok, so the main problem is the fact that you are putting exhaust gasses into the intake. It's not going to burn. The car intakes oxygen and gas, and exhausts CO, CO2, and NOx, (and other byproducts of an imperfect burn). This won't burn. Sorry man, try again.
Old May 22, 2007 | 08:49 AM
doubleoray's Avatar
doubleoray
Default not a bad plan, but it ignores what "air" actually is
You need an oxidizing agent for combustion (here O2) which is converted in the reaction with the hydrocarbons CxHx into CO, CO2, and H2O. You could pipe in pure 02 from a cylinder.
Old May 22, 2007 | 08:52 AM
ecorona6's Avatar
ecorona6
This was my first thought...Wouldnt the exhaust cause damage to the engine if the engine is running rich. I have seen many cat's go down due to fuel problems. I cant amagine those gases going back to the intake and not causes severe damage to our engines.
Old May 22, 2007 | 08:58 AM
ZTUPID's Avatar
ZTUPID
I'm sure people laughed at the guy who thought up forced induction. Now, I don;t think the issue would be "dirty exhaust" as much as a lack of oxygen.
Old May 22, 2007 | 09:13 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Why not just put an impeller in the exhaust stream to rotate a shaft - on the other end of that shaft would be a compressor blade which would rotate compressing the intake air? You could put one into each exhaust manifold to create twin rotating compressors.
Old May 22, 2007 | 09:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I give you props for posting something so silly on a public forum.
thanh27's Avatar
thanh27
blowdry's Avatar
blowdry
I am no mechanic, and I am not flaming you. It sounds like a turbo setup w/out the turbos and pressure.
*I've always understood F/I as exhaust from the manifold spooling the turbos, thus building up pressure, air(exhaust) being rushed through piping to an intercooler, back in to the intake manifold under pressure w/more oxygen to mix w/ fuel.
I have never thought of how that exhaust is purified. Oh wait maybe the exhaust spools the propeller of the turbo to suck in the clean air!!! I think that's why you seen an intake filter on the turbos. I just figured that out, sorry for my noobness.
*I COULD BE WRONG. I HAVE NEVER REALLY TAKEN TIME TO READ ON FI.
Old May 22, 2007 | 09:20 AM
robbycolli's Avatar
robbycolli
This is a great idea! Someone should design one of these. You have now fixed the lack of O2 problem but maintained the idea of air being forced into the engine.
Old May 22, 2007 | 09:23 AM
Ghost 350z's Avatar
Ghost 350z
If you can figure out how to make exhaust gases combustible I bet you could figure out how to bend the space-time continuum
Old May 22, 2007 | 09:39 AM
MUZZY's Avatar
MUZZY
this will not work.............
seriously u cant get much power from recombusted gas. fire needs fuel + oxygen....... combusted exhoust gas has almost no oxygen. hence why ppl comit suicide by filling the car with exhoust gas.
hence only thing good about exhoust gas is its pressure and hence why turbos are invented. they harness that power and convert it into suction of new air
MR_X's Avatar
MR_X
Ok well i just thought about something and iam by no means a car expert, but am by no mean a moron so dont judge me off this one moronic comment . So i was thinking to my self, what if you can take piping from the exhaust striaght off the headers (maybe redesign the headers alittle) and have those pipes connect to a intercooler like a turbo, then super chill the air w/ one of those Smax intercooler things a few posts down or something similar, then feed it back into the intake manifold. I would create much more air flow like raming in alot of air, similar to a turbo except well...not. But then i started thinking well that can work because all that would just be a closed circuit and would build up hella pressure, so something like a valve, omg BOV?!?! that would let some exhaust out and some still into the intake. I figure it will definently provide more air then just an intake, and the pressure would help, but its just alot of hot air. So if you can cool it and somehow make it so some air can escape, maybe it would be ok? I mean hell, air coming from a turbo is probably alot hotter before it goes through the intercooler then just normal exhaust air. Any ideas?
Is hard to believe that statement after something like that gets posted.
In a serious note, If that was possible, then why have we not seen this before? There will be no emissions to worry about, ETC.
Old May 22, 2007 | 09:51 AM
97supratt's Avatar
97supratt
Guys! Guys! I've seen one of these things he's talking about, here it is! LMAO
Old May 22, 2007 | 10:00 AM
03BrickyardZ's Avatar
03BrickyardZ
Hey, everybody here has asked something out of ignorance before... Give the guy a break.
To the OP, look up howstuffworks.com and read up on the internal combustion engine. That should give you an idea of why it wont work, and you'll have better questions to ask in the future.
Old May 22, 2007 | 10:02 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Umm. Is he serious?
