Megan Test Pipe Keeps Cracking!
Old May 24, 2007 | 11:29 AM
06MagneticZ's Avatar
06MagneticZ
Default Megan Test Pipe Keeps Cracking!
Stupid Megan tp keeps cracking. The one on the passenger side already cracked once, had it welded and cracked a month later. Was welded again and cracked again the very next day!! I guess its time to throw it out :-( Car sounded so good with them on. I know its because there are no brackets though.
Has anyone else had this type of problem with tp's?? Guess Im back on the market for a new set of resonated tp's.
Old May 24, 2007 | 11:30 AM
jdm21bmx's Avatar
jdm21bmx
I have seen alot this while researching test pipes for my z. I also wondered if anyone has welded thier own brackets to these, to support the problem?
iStan's Avatar
iStan
ZR
Same place cracking?
Old May 24, 2007 | 11:49 AM
06MagneticZ
Yessir...same spot. Actually it seems to be cracking along the new weld. They put a pretty thick bead which overlapped the existing weld and it cracked along the new weld. I know you're not really supposed to weld these the same way you would a regular pipe...I think. But it helped at first. Im pretty sure that brackets can be added, but Im not sure where they'd mount. I'd have to look.
Old May 24, 2007 | 11:55 AM
groovin_350z's Avatar
groovin_350z
Sleeps in 350Z
yea. megan sucks. u should just spend a lil more for some crawfords or something else.
Old May 24, 2007 | 11:56 AM
THE TECH's Avatar
THE TECH
Which exhaust do you have? Nismo IIRC?
Old May 24, 2007 | 12:00 PM
06MagneticZ
Yup Nismo. I remember you warned me about this. I thought it was something that would happen over a long period of time.
blasian's Avatar
blasian
I have the Nismo exhaust but I have test pipes with braces... They aren't resonated though.
Old May 24, 2007 | 12:01 PM
skimnismo's Avatar
skimnismo
consider getting TITEK...kinda expensive...but its good...
Old May 24, 2007 | 12:44 PM
blasian's Avatar
blasian
Originally Posted by dave079
I would buy something better than Megan. They are known to be garbage.
+1
I had cheap ones... now I have Helix and I think they're awesome but I'm about to get some TurboXS test pipes though.
Old May 24, 2007 | 12:46 PM
Nexx's Avatar
Nexx
titeks are badass. quality is awesome. for less then $200, by far the best test pipes.
Old May 24, 2007 | 12:48 PM
Nexx's Avatar
Nexx
Originally Posted by blasian
+1
not sure if turboxs has fixed this but their hanger welds were terrible. looking at the quality of their hanger weld vs titek's, even the untrained eye could see that titek's was far superior. i know someone on this board had his turboxs test pipe crack at the hanger weld.
Old May 24, 2007 | 12:50 PM
blasian's Avatar
blasian
I have two friends out here that have the TurboXS locally and haven't had a problem so far.
Are the Titek 2.25" in and out?
Old May 24, 2007 | 12:52 PM
THE TECH's Avatar
THE TECH
Just depends. Some get lucky and can go a while. Others have problems right away. All you really need is to have a muffler shop weld a brace on.
Old May 24, 2007 | 01:12 PM
Question
Photos always appreciated.
How many miles on the pipes?
Did you attempt to contact Megan, and ask for a refund or replacement?
Old May 24, 2007 | 01:18 PM
Nexx's Avatar
Nexx
2.25" inner.
Old Sep 14, 2007 | 05:58 PM
moog's Avatar
moog
hmm...just had my 1 month old Titek test pipes crack at the hanger weld
Old Sep 15, 2007 | 12:49 AM
gsazabi's Avatar
gsazabi
It's about time mods make a sticky thread titled "MEGAN TP CRACKS AVOID THAT POS!"..for reals...
Old Sep 15, 2007 | 12:51 AM
SuperBlack350z's Avatar
SuperBlack350z
as cheap as test pipes are, can't you just dish out a couple of extra $$ for decent ones? All the times you are goign to weld it, you can just get a good set.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
