advantage of an x pipe?
Old Jun 15, 2007 | 09:53 AM
savefatkids's Avatar
savefatkids
Default advantage of an x pipe?
i have a cutom TD exhaust on my g35. its basicly 2 straight pipes from the cats back. i was thinking about adding a X pipe. what are the pros and cons of an x pipe?
Old Jun 15, 2007 | 09:54 AM
kwiker's Avatar
kwiker
Shift_Dorifto
It scavenges better, it should help...DO IT.
Old Jun 15, 2007 | 09:56 AM
savefatkids
would it sound any different?
Old Jun 15, 2007 | 10:30 AM
kwiker's Avatar
kwiker
Shift_Dorifto
yeah, it will sound like a 6 cylinder instead of two 3 cylinders running next to each other....if that makes sense? Which it probably doesn't, b/c i'm having trouble making sense of it.
Someone [...] help me [...] please?
edit: I'm sure you will see some small gains though, nothing big...it's hard to see large gains on a stock N/A setup.
Old Jun 15, 2007 | 10:36 AM
lowrider's Avatar
lowrider
Someone [...] help me [...] please?.
I have an Invidia G200 and your comments are correct. I added an "H" pipe to mine, and it smoothed things out at idle. At idle it sounded like you said, two 3 cylinder engines. It also had a lop. The "H" corrected this.
Lou
Old Jun 15, 2007 | 10:49 AM
Flee0588's Avatar
Flee0588
In an N/A car, a little back-pressure is welcomed for a smoother idle + low-end torque. The X-pipe will deliver on this. The problem with TD exhausts on an NA car is that it expels the exhaust gases too quickly. While this is ideal for a FI, it is not for NA.
Old Jun 15, 2007 | 02:12 PM
savefatkids
how will an x pipe sound? raspy?deep? throaty?
Old Jun 15, 2007 | 02:19 PM
I think you mean...
Exhaust volume increases.
Exhaust velocity decreases.
Old Jun 15, 2007 | 02:23 PM
Exhaust pressure on either side will be equal after the X-pipe. Not certain if this is a performance advantage.
Old Jun 16, 2007 | 01:33 AM
savefatkids
would an h pipe be a better option?
Old Jun 16, 2007 | 01:44 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I guess you have diagnosed this "problem" after seeing hundreds of dyno charts with true dual exhausts losing power on N/A?
I agree that the X-pipe will help, but not because of any of the reasons this guy just said.
I guess the backpressure myth will never die!
Old Jun 16, 2007 | 08:36 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
X-pipes are more efficient at scavenging exhaust gases, and therefore increase and balance flow. Some x-pipes are made better than others, and do a better job. In an H-pipe, once the pressure builds in the H, the benefit gets stagnant - hence a reason that H-pipes can deliver a little better bottom end, but loose at the top.
At higher RPM rates, X-pipes are more efficient, and can provide for more horsepower, as long as the rest of the exhaust system is designed properly as well.
Years ago, I did some tests on H v. X and found the X to give more HP overall, by about 2-6 HP, depending on mods. For an FI car, the X is best, as the more flow and better scavenging, the greater gains overall. Keep in mind, these test were done on 6 cyl..not 8 cyl..so I don't know the difference of that rate, which the former is more on topic anyway.
Rick
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
