Help with removing test pipes
Old Jun 20, 2007 | 03:37 PM
filmnews's Avatar
filmnews
Default Help with removing test pipes
How do I get these bolts off? I have been pulling on these damn things for an hour. Please HELP!!!!!!!!!!!!!!!!!!1
Old Jun 20, 2007 | 03:39 PM
iStan's Avatar
iStan
ZR
Um, Keep tugging. Not much else you can do. Just try to keep moving around and pivoting yourself in different positions.
Old Jun 20, 2007 | 03:40 PM
filmnews's Avatar
filmnews
I sprayed it with WD-40, and that did not help. Are the top bolts this hard to get off?
Old Jun 20, 2007 | 03:49 PM
iStan's Avatar
iStan
ZR
Harder. There is an 'easier' way for the driver's side, but I rather not try to explain that over the internet.
Just keep wrenching. It'll break.
Old Jun 20, 2007 | 03:56 PM
filmnews's Avatar
filmnews
I even used my leg on the wrench, and this will not move.
Old Jun 20, 2007 | 03:57 PM
iStan's Avatar
iStan
ZR
I feel your pain. Just relax for a bit and go at it again. More WD40.
Old Jun 20, 2007 | 06:01 PM
failsafe306's Avatar
failsafe306
Breaker bar
Old Jun 20, 2007 | 06:03 PM
SuperBlack350z's Avatar
SuperBlack350z
honestly, unless you have good tools, you will need air tools, good penatration grease, and special sockets to get the top bolts near the headers. WD40 won't work in this case. They are on there good.
Old Jun 20, 2007 | 07:04 PM
h8bumps's Avatar
h8bumps
My bolts came off easily, but another board member's (Datona Jess) were much more difficult to remove. Make sure the car is up high enough (we did it without a lift) so you have room to move around on a creeper. Try different ways to weave your arm up around to the top side of the cats. Use a combination of different length extensions and maybe a universal joint for the socket, especially for the driver side. A small pipe can be put over the wratchet handle for extra leverage.
I think we used both regular and deep well sockets, and a combination of 1 1/2" and 3" extensions, as well as a universal joint. Experiment with different combinations to get something that fits in the limited clearance. On the driver side I weaved my empty hand up through the suspension, then handed myself the ratchet with my other hand (it will make sense once you do it).
They'll come off -- just use some force. And liquid wrench isn't a bad idea either.
Edit: And how did you use your leg on the wrench? If you can't break loose the 'easy' nuts on the header end, you might need help. That one should come right off with a breaker bar (or wratchet and pipe).
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
