Those of you with Kinetix Plenums or other plenums
Old Jul 16, 2007 | 02:56 PM
johnnyblaze's Avatar
johnnyblaze
Default Those of you with Kinetix Plenums or other plenums
Before i get flamed about the MREV2 + 5/16 Spacer combo thats been beaten to death, this question is a bit different. I've done my homework and searches :P
Mostly for the Non-revup people,
Option #1 keeping the kinetix plenum and throwing the spacer or MREV2 on.
Did you add a 5/16 motordyne spacer? or an MREV2 collector? Im worried about strut bar clearance. I have a Kinetix v4 installed right now and i want to get the spacer because i heard it helps. But having the kinetix plenum already might do the job the spacer would, and im debating getting the MREV2 because I dont think i would have a problem with clearance. The Kinetix plenum is already a pretty tight fit, I fear adding a little bit will even push it too hard against the strut.
Option #2 Ditching the kinetix plenum and adding the spacer with the stock plenum.
Anyone with a similar setup have opinions? Or know that i would have clearance problems?
Old Jul 16, 2007 | 03:23 PM
05zissan's Avatar
05zissan
this might help:
https://my350z.com/forum/intake-exhaust/283170-intake-manifold-5-8-spacer-what-strut-bar.html
Old Jul 16, 2007 | 03:45 PM
johnnyblaze
Originally Posted by 05zissan
Thanks for the quick reply. Helped me further in my decision. But im still wondering one thing.
Anyone else have both Kinetix and Spacer? Since I already have the kinetix I dont really feel like throwing it away unless i can see that it didnt help or it atleast hurt the gains on the car. Dont really feel like pulling off and on the plenum a bunch of times.
Old Jul 17, 2007 | 04:38 AM
HondaKiller's Avatar
HondaKiller
adding a spacer to your kinetix plenum will probably yeild no further gains. Honestly, there is a thin line between too much and too little when it comes to the plenum spacing. The only gains you coudl probably yeild are with the MREV2 but with a non rev up engine be prepared to reflash/tune your car after installing it. Good luck with your decision.
Old Jul 18, 2007 | 09:22 PM
easyas1_2_350Z's Avatar
easyas1_2_350Z
hmm im wondering the same thing myself
Old Jul 19, 2007 | 06:21 AM
IIQuickSilverII's Avatar
IIQuickSilverII
go with option 2...option 1 is worthless...
Old Jul 19, 2007 | 06:48 AM
I recommend that you do not mix and match upper plenums and spacers.
Old Jul 19, 2007 | 07:06 AM
taurran's Avatar
taurran
I agree. Spacer and stock plenum wins!
Old Jul 19, 2007 | 09:51 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Certaintly don't mix the spacer with a upper plenum. Wont fit.
You would be able to do a little better by adding a MREV2 to your Kinetix, but I don't think the difference would be worth the added cost.
If you had a REVUP engine, then I would absolutely recommend it.
allmycarsdie
May 13, 2016 04:38 PM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
_koubie_
Sep 20, 2015 06:34 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
