Throttle Body Porting - Any gains? Been Done?
This was a modification done on the supercharged 4.6L cobra motors. Worth about 6 to 12 horsepower. I will pull off one of my throttle bodies and see if any clean up is needed - maybe not?
well, it could probably help this car if done in conjunction with a larger maf housing and with a larger plenum neck opening but i dont believe anyone has tried it...
TB, plenum neck and maf housing measure to 2.75 inches, so if you do one, you need to do them all
Its been done, and its alot of work for the gains. (big mouth plenum, large TB, large intake tube w/ MAF)
One of the major issues is when you change the size of the MAF tube, you need Utec or EMU or some way to retune the car. It really messes up the tune when you change the tube size. It will not run on a stock ecu.
I have mine 'ported' and it made a nice different in the smoothness. NO DYNO (sorry folks)
it wasn't ported in the sense of making the whole opening larger, and I retain the stock butterfly... WRPtechnologies (screenname: Wperdigon). I don't want to give away his technique, but it uses the same idea as the JWT intake...
It was very cheap as well, under 100 bucks and I noticed a smoother characteristic afterwards, especially in the higher RPMS.
yeah he does, letmecheck. he just had some parts featured in Sport Z Magazine he developed...
http://www.wrptechnology.com/
the website is not fully built yet (looking at you sean
) every tab directs you to email: mailto:sales@wperdigon.com but you can PM him on this site, or at fresh alloy where he is a moderator.
It looks like its been tried a few times on the DE motors (a guy by the name of aceman or something along those lines? as well as Crawford)
I don't think there was any real conclusion from it though dynowise...
Hey guys -
Yes the throttle body porting does work, it espicially works on the QR25 ( I know it's not the same engine), but the technique is the same and results tend to be a smoother and faster rev in addition to 2-4 hp more. I dyno'd with the Sentra community and these where the results -
I am still building my website, so please bear with me since it's not listed on the site - but I do offer it and it's 65 dollars to have it done -
Turn around time is usually 2-3 days - pm me if interested
2-4 hp gain? Most members, including myself on this forum would constitute that as just dyno fluctuation margin. Too many factors to test a mod like this, IMO. Not calling you a liar or anything, but im not sure minor porting will gain much or be able to show measurable gains on pretty much any dyno...
I had my Throttle body ported by proflow design.
here is the thread
https://my350z.com/forum/intake-exhaust/223208-larger-maf-housing-intake-pipe-and-tb-installed.html
Stock figures are:
Maf ======== 72mm
Intake pipe ===72mm
TB ==========70mm
Larger Pieces
Maf =========80mm
Intake pipe====85mm
TB========== 2mm oversize at 72mm, with the inlet enlarged to 78mm.
And im using the crawford big mouth plenum tuned with a UTEC
And still no dyno to prove anything
Later
Todd
here is the thread
Stock figures are:
Maf ======== 72mm
Intake pipe ===72mm
TB ==========70mm
Larger Pieces
Maf =========80mm
Intake pipe====85mm
Later
Todd
