Threw a PC420 and PC430 CEL's...
Old Aug 20, 2007 | 12:57 AM
Armitage's Avatar
Armitage
Default Threw a PC420 and PC430 CEL's...
Running 5/16" MD spacer, UR HFC's, and Nismo exhaust. Is it plausible that the HFC's caused the CEL's and I'll have to throw on some O2-non foulers?
P0420 OBD-II Trouble Code
Technical Description
Catalyst System Efficiency Below Threshold (Bank 1)
What does that mean?
Basically this means that the oxygen sensor downstream (after) the catalytic converter on bank 1 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
0430 OBD-II Trouble Code
Catalyst System Efficiency Below Threshold (Bank 2)
Basically this means that the oxygen sensor downstream of the catalytic converter on bank 2 (passenger side) is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions system.
Anyone ever had HFC's set off a CEL for the cats not working?
Old Aug 20, 2007 | 05:25 AM
HondaKiller's Avatar
HondaKiller
Yeah, mine threw a light a month or so ago. I had a blown out gasket from the header to the cat, Once i replaced it, reset the ECU, it went away and stayed away. Not sure if this will help you or not though. (the gasket swap was a *****) Also, have you been using fuel addtitives regulary? Those are known to clog the filters in the HFC's and envoke cat failure.
Old Aug 20, 2007 | 10:53 AM
Armitage's Avatar
Armitage
No I don't use additives. Maybe I'll try replacing the gaskets though.
Old Aug 21, 2007 | 06:12 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Default DTC troubleshooting for P0420-P0430
Take a look here...
http://www.ismcentral.com/dtc/DTC_P0420-P0430.pdf
I extracted these pages for you.
Rick
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
KONVERTER
Aug 18, 2003 10:40 AM
webcarconnection
Jul 16, 2003 07:25 PM
