test pipes...
Old Aug 23, 2007 | 07:27 PM
memphis350z's Avatar
memphis350z
Question test pipes...
im lookin at getting some test pipes and i just got a couple questions to those out there with them...
1.What are some good ones.
2.Will the pest pipes 'throw a code' and what can be done to prevent this
3.What was the pros/cons you observed
Old Aug 23, 2007 | 07:32 PM
SuperBlack350z's Avatar
SuperBlack350z
1. Most of them are good. I really don't want to list all the ones that are not prone to cracking. Ones i would stay away are Megan racing ones. A lot of people choose to go cheap and get teh Megan but you it will crack and you will have to buy new ones and teh install which isn't too fun.
2. Yes, they will throw a code. You can get spark plug defoulers which aren't expensive and put them on the test pipe, then put the o2 sensor through that.
3. Pros are that the gains are actually good. I was skeptical but i sure felt the gains.
Cons are that it smells bad. The smell is toxic if you smell it too much. Test pipes can make your car sound bad or really loud depending on what exhaust you are running. They rasp but the resonated suppose to take some of the raspiness away. I'm running non resonated test pipes on my stock exhaust and it sounds real good.
Old Aug 23, 2007 | 08:00 PM
Get_Zwole's Avatar
Get_Zwole
put mine on 3 weeks ago.
Pros def increase in power.
pros def. louder then stock
Cons rasp
Cons rasp
imo pros outway cons
Old Aug 23, 2007 | 08:50 PM
thanh27's Avatar
thanh27
Well, I have read and read about test pipes and HFC's and to me, is it that much MORE gain going TP over HFC in comparison to going HFC and not throwing code or getting the smell and such?
Old Aug 23, 2007 | 08:58 PM
UHATEIT's Avatar
UHATEIT
Get resonated ones to avoid rasp. you will get it regardless tho. they will throw codes unless you get spark plug nonfoulers ($4-5 at pep boys for a set of 2, and you need 2 per plug) Either way when you try to pass smog you will have to put your stock cats back on there.
Sound is amazing if you like it loud and to **** people off! They smell at the beginning but then you get used to them. When I first got them the smell was horrible and it droned so loud I got a headache when driving on the freeway next to the center divider. But then I got used to them.
Get the right tone and you'll sound like a nice ferrari
Old Aug 23, 2007 | 09:09 PM
SuperBlack350z
actually, the only states i know that does smog in the term you area talking about is in cali and nevada. Here in nc, as long as you don't have a check engine light, you will pass. They dont' do visual inspection.
Old Aug 23, 2007 | 11:52 PM
HDPDZO6's Avatar
HDPDZO6
Nevada does OBDII testing on newer vehicles. They won't do the sniff test unless they encounter problems.
Old Aug 24, 2007 | 05:01 AM
ZLadie2000's Avatar
ZLadie2000
Cons rasp
Cons rasp
u throw a code?
Old Aug 24, 2007 | 07:03 AM
VTS's Avatar
VTS
I put resonated test pipes on about 3 weeks ago. They have yet to throw a code and they sound awesome on my stillen td exhaust. The only time I get rasp with them is if I get on it before its good and warmed up(which I rarely do) .I get compliments all the time on how they sound and I have even been told that it sounds like a ferarri . They do smell a bit but the power and sound boost makes it worth it imo.
Old Aug 24, 2007 | 01:19 PM
Helix SS Test Pipes with non-foulers. 3,768 miles and no problems. Passed Maryland emissions test.
Old Aug 24, 2007 | 01:22 PM
Cannysage's Avatar
Cannysage
I had kinetix resonated.. I had it for awhile and there were no crack, no nothing.. heldup like a champ.
Old Aug 24, 2007 | 02:13 PM
Ruthless18x's Avatar
Ruthless18x
1. APS
2. Non Foulers
3. 10+ WHP Proven
Old Aug 24, 2007 | 02:18 PM
HondaKiller's Avatar
HondaKiller
i run HFC's and loved the sound improvement they provided. No rasp at all, no smell, no complaints. I haven't dyno'd my car before and after, but knowledgable people claim HFC's dont produce half the hp as test pipes. I would consider your emission laws and budget and go from there. I did notice a little more mid range pep after installing them, but most of all it made my exhaust sound tone much deeper and aggressive.
Old Aug 24, 2007 | 06:19 PM
datboijon's Avatar
datboijon
in cali isnt there a hefty fine if u get busted with tp's???
Old Aug 24, 2007 | 07:19 PM
DIMERYDER's Avatar
DIMERYDER
-Kinetix Resonated TP's
-I added Nismo Headeres and it sounds even better, got rid of the drone at 2k-3k rpm.
-did not have to use non-foulers on my '03, no CEL
here's a sample vid of my Z. (also has Nismo exhaust.)
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
