Installed crawford headers and tuned, no gains
Old Sep 4, 2007 | 12:51 PM
  #41
97supratt's Avatar
97supratt
Here's a link that shows a 8whp gain on a auto with no tuning stock ecu...
https://my350z.com/forum/showthread....=crawford+dyno
Old Sep 4, 2007 | 12:52 PM
  #42
97supratt's Avatar
97supratt
This is on a REVUP with bolt-on's and stock ECU.
You'll really like this one.
Old Sep 5, 2007 | 08:11 AM
  #43
VandyZ's Avatar
VandyZ
On my personal car with all crawford parts and a tune I made 263 at the wheels. With the milder cams, i moved up to 275. That is only peak numbers tho. The most impressive part is comparing the redline numbers where there was a much larger jump in power.
Sorry to see your results. I would be right there with you on being suspect of something, but I can tell you that the headers are solid performers.
Old Sep 6, 2007 | 10:07 PM
  #44
mthreat's Avatar
mthreat
Yeah...since the headers are already on, I'd like to try and get the gains out of them. Any suggestions on possible things that I could start checking that could be preventing the hp gains?
Old Sep 20, 2007 | 09:30 PM
  #45
mthreat's Avatar
mthreat
Update: I have replaced my cats with a brand new set of Crawford high-flow cats, and my exhaust with a Fujitsubo titanium exhaust, with a Megan y-pipe. So I am pretty close to your setup, VandyZ. I think the difference between your car and mine are: Big Bore TB, clutch/flywheel, and you have the TS ECU, I have the Uprev reflash.
The new exhaust is awesome sounding, but without doing another dyno, I can't tell if it's faster or not. If I get a chance, I'll try to do some more tuning with Jared on the dyno at Uprev. Any recommendations for tuning Air/Fuel and timing for best gains with Crawford headers are appreciated.
So to reiterate, here is my full set of engine mods:
JWT popcharger intake
Crawford V5 plenum
Crawford headers, jethot coated
Crawford high-flow cats (replacing gutted ones)
Megan y-pipe
Uprev reflash & tuning
Old Sep 21, 2007 | 04:02 PM
  #46
plumpzz's Avatar
plumpzz
I definatley suggest waiting for cams. Mild to semi-aggressive cams can push 280whp on that setup. JWT S2 (i think those are the ones that fit the 287VQ) are would be a good chocie. I want headers and cams next
2ndchanceZ
Oct 26, 2015 08:03 PM
