Cold air, short ram, drop in?
Old Oct 26, 2007 | 07:10 AM
  #41
350Zrunnin12s's Avatar
350Zrunnin12s
so for an 07 would you recommend the popcharger or a drop in?
Old Oct 26, 2007 | 08:44 PM
  #42
Fairly Z's Avatar
Fairly Z
. . . Man, we need some serious dyno-sheetage. This thread is useful in that it has opinions, but everyone's just arguing with one another. It's not helping any of us make a final decision. I'm going to No Limit Motorsport tomorrow to review a stock Z vs. a stock Z with a K&N drop-in. I look forward to seeing the results.
Old Oct 27, 2007 | 07:16 AM
  #43
350Zrunnin12s
do thye have a popcharger for an 07 hr Z? if so wher ecan i buy, if not do they have a k&n drop in for the 07 HR Z? if so what model number!
Old Oct 27, 2007 | 08:24 AM
  #44
Beeker's Avatar
Beeker
I have verified using Cipher that the popcharger air intake temps drop very quickly once you are moving. When sitting in traffic, temps rise but as soon as you start moving they drop almost immediately. That is the case with the stock air box as well. There was a thread about this over a year ago. The OP ran tests with the popcharger and stock air box. The popcharger did have slightly higher intake temps when idiling but they dropped as soon as you start moving. I don't think heatsoak is an issue with the Popcharger. If you live in Phoenix and drive in stop and go traffic all day then that may be a different story. Of course even the stock air box will get heatsoak in those conditions.
From what I've read the Popcharger is a great option on 03-05's. In 2006 Nissan added a velocity stack to the stock airbox. So if you have a 2006 a K&N drop in is probably the best option. Of course if you like the sound of the popcharger get it. It should perform just as well as the stock air box.
If you have a 03-05 either get a Popcharger or a 2006 airbox with a K&N drop in.
Old Oct 27, 2007 | 04:16 PM
  #45
350Zrunnin12s
so for my 07 just get a k&n drop in for like $50 bux?
Old Oct 28, 2007 | 12:08 AM
  #46
md350's Avatar
md350
You have two intakes, not one. Don't think they make them for 07 Z's yet though.
Old Oct 28, 2007 | 06:42 AM
  #47
Z04's Avatar
Z04
Originally Posted by blck350
ok time for a science lesson
Hot air and cold air
colder air is more dense because particles are closer together (much better for combustion and you can get away with slightly less flow even if that was the case)
hot air is the oposite even if you for feed your engine more less dense air your not gettn the benifit of the cooler air
A cold air intake is better, of course like some one has said you have to take into acount that the air may need to be re routed toward a cai but a tube with a filter is a tube with a filter the only real differance is if you can get the air and make it cooler and denser when it enters the engine
thats why i said the K&N drop in shouldnt be better than a good cai it is much cheaper but how could it be better and i see no possible way a short ram makes any since but thats jsut me
um, i think you need to rethink your "science". long read warning but worth it
Originally Posted by Neuspeed FAQ
Question : What's the difference between a stock airbox, a short ram system (open intake filter), or a CAI (Cold Air Intake)? Isn't the CAI the best since it draws cold air? Won't the short ram system just draw hot air and cause my engine to lose power?
Answer : A short ram system usually refers to a open filter (cylindrical or conical shaped) attached directly to the mass air flow meter, or attached via a short velocity tube. In some applications, a heat shield surrounds the filter to reduce the effects of radiant heat coming from the engine. A cold air intake usually refers to either a heat shield that seals to the hood and surrounds the sides and bottom of the filter, or a long extension tube that relocates the filter in the front fenderwell.
The Science Behind an Air Intake
You've probably heard this before on the internet, "...colder air is denser air, and that means more horsepower." In fact, you've probably heard this enough times that you're convinced it's true, right? Well this might throw you for a loop then: It's entirely possible to gain horsepower with just an open element intake. Drawing in air that is warmer than the outside air does not automatically equate to a horsepower loss when the stock airbox has been removed. Now here is the science behind that statement.
When looking at the properties of gases (and air is a gas) the actual scientific equation for density is:
Density = mass / volume
A quick review of our science book tells us to increase air density you could increase the mass, or reduce the volume. To increase mass, you could increase pressure or reduce temperature. To reduce volume you could increase pressure or reduce temperature. So air pressure and temperature are the two common variables that we have to work with. Everyone likes to talk about temperature, but very few people ever address pressure. Pressure and temperature are equally important.
Pressure, Temperature, and SAE J1349
The Society of Automotive Engineers (SAE) has established a test standard that helps standardized engine horsepower testing and results so that the variable effects of barometric pressure, altitude, and intake air temperatures do not bias the test results. The SAE J1349 test procedure includes an engine horsepower correction factor so that, for example, dyno readings taken at 3500 feet on a 40 degree day can be compared with dyno readings taken at sea level on a 77 degree day.
This correction factor is used for Normally Aspirated Engines, not forced induction engines. Once the correction factor is determined, it can be applied to the actual dyno readings so they can be adjusted back to simulate a test conducted at sea level, on a 77 degree day, with 1% humidity.
The SAE correction factor can be approximated using this equation:
CF = 1.18 * (29.235 / Bdo) * ((square root (To + 460) / 537) - 0.153)
where CF = the correction factor, Bdo = the dry ambient barometric pressure in inches of mercury (in/Hg), and To = the intake air temperature in degrees Fahrenheit.
Test 1: The Baseline Test
Let's test this equation with a hypothetical engine that dynos at 100HP. We test this engine on a 77 degree day, at sea level. So, we set Bdo = to 29.235 in/Hg and To = to 77F. When we solve the equation for CF, the correction factor equals 1. That means according to SAE, our dyno reading does not require a correction factor for temperature or barometric pressure. It is a true 100HP engine.
Test 2: Temperature = 87 degrees F, Pressure = 29.235 in/Hg
What happens when the temperature climbs by 10 degrees, but pressure stays constant? Plugging in 87 for To and 29.235 for Bdo, we can calculate the value of CF. CF = 1.0104. Working our correction factor equation backwards, we take:
100hp / 1.0104 = 98.97hp.
So, according to the SAE correction factor, a 10 degree increase in temp should result in a loss of 1.03% of rated horsepower, or 1hp on our engine.
Test 3: Temperature = 77 degrees F, Pressure = 28.235 in/Hg
What happens when the pressure drops by 1.0 in/Hg, but temperature stays constant? Plugging in 77 for To and 28.235 for Bdo, we calculate CF and find it equals 1.042.
100hp / 1.042 = 95.96hp.
So, according to the SAE correction factor, a 1 in/Hg drop in air pressure should result in a loss of 4.04% of rated horsepower, or 4hp on our engine.
Wow! A drop of 1.0 in/Hg in air pressure is roughly equivalent to climbing approximately 1,000 feet in altitude. That's not very high. The Sear's Tower in Chicago is 1353 feet tall. So, if we put our car in the Sear's Tower freight elevator and take it to the roof, now we have an SAE correction factor of approximately 1.060. We lost almost 6hp just going from the ground floor to the roof level !!
What Does It All Mean?
When designing a P-Flo intake, it means we are concerned about how much pressure loss is caused by the stock airbox. For example, barometric pressure at sea level may be 29.235 in/Hg, but air pressure drops as air enters the factory airbox and passes through the filter. So the pressure below the air filter element (on engine side of the intake system) is going to be less than 29.235. How do we know this? There is another SAE test, J726, that is used to calculate the efficiency of air filters. One of the variables measured in this test is the air pressure drop caused by the factory airbox and filter element. We call this pressure drop "Delta P" or differential pressure.
Would you be surprised to find that during the SAE J726 test, the stock airbox can cause a Delta P of anywhere from 15-20psi, depending on the CFM moving through the intake tract? And that just changing the filter element material can result in a 1-5 psi difference? Want to test this in real life? Take a normally aspirated car like the Golf VR6 or the Acura RSX and run two back-to-back dyno tests: One test with the airbox on, one with the airbox totally removed. Did you find a horsepower gain at the higher RPMs without the airbox? You gained HP, and yet the intake air temperature stayed the same or maybe even went higher. So part of the Delta P is caused by restrictions in your factory airbox.
However, during the SAE J726 tests we conducted, we found the Delta P to be lowest when an oiled cotton gauze filter material (K&N style) is used. Synthetic foam filters have the highest Delta P due to the lubricating polymer they are typically coated with. So the other component to lowering Delta P is choosing the air filter element that flows without much restriction, yet still traps dirt.
So, in summary it is entirely possible to gain horsepower just by moving to a short ram intake. Reducing the Delta P will be an improvement on its own. Of course, if you can reduce intake air temperatures AND reduce Delta P, then you have the best of both worlds. But given a choice between the two, Delta P is more important for most vehicles. NEUSPEED makes short ram systems (with and without heat shields) and "CAI" cold air intakes. So the type of filter kit offered for your car is based on what worked the best during our design and testing.
Be advised that CAI systems that place the air filter down into the front fenderwell should not be used in wet, rainy conditions, especially in areas that experience excessive puddling or patches of standing water. If you operate your car frequently in these conditions, we recommend that you use our short ram systems instead to avoid ingesting water into your engine. Water ingestion is a very serious problem and can lead to extensive engine damage.
Try It Yourself
Here's an online calculator where you can input different pressure, temperature, and altitude values to see how they affect your engine:
http://www.csgnetwork.com/relhumhpcalc.html
Old Oct 28, 2007 | 09:32 AM
  #48
350Zrunnin12s
do i need 2 drop in filters then?
Old Oct 28, 2007 | 01:41 PM
  #49
SergEK's Avatar
SergEK
Originally Posted by davidv
You will be pleased with the pop charger. Its a simple design with proven performance.
Amen
Old Oct 29, 2007 | 11:03 AM
  #50
A3VT 74's Avatar
A3VT 74
Everybody talks about the K&N drop in ... have you considered or know anything about GREEN high performance filters? I think is a better choice over K&N.
Old Oct 29, 2007 | 12:54 PM
  #51
gothchick's Avatar
gothchick
Try It Yourself
Wow, that is quite a lesson in air intake theory. But didn't Jeremy @ Performance Factory run back to back dynos on the same setup / same day using CAI, Shortram and the Stock airbox -- showing that everything except the stock airbox actually lost whp? CAIs lost up to 8 whp compared to the stock airbox.
The only real improvement I could see over the stock airbox for NA would be the Gruppe-M. But that intake is even more expensive than ARC. I believe Adam @ Z1 is running the Gruppe-M on his 305whp NA build...
Old Jul 1, 2008 | 07:47 PM
  #52
1redZ983's Avatar
1redZ983
if you have an 07. yes you do
Old Jul 1, 2008 | 07:54 PM
  #53
SpoilsofWar's Avatar
SpoilsofWar
Wow, nice year old thread bump.
Old Jul 5, 2008 | 09:33 PM
  #54
kenpo_350Z's Avatar
kenpo_350Z
So where are the dyno sheets?!
Old Jul 7, 2008 | 07:30 AM
  #55
gothchick's Avatar
gothchick
Nice waking dis fread from da dead yo. In fo da dyno sheetz. I can haz?
Old Jul 9, 2008 | 07:29 AM
  #56
hran's Avatar
hran
i've been thinking about a pop charger as well... but i think i will go for the k&n drop in since i hear these terrible stories about popcharger shutting your car off at random.
Old Jul 10, 2008 | 03:14 AM
  #57
Z04's Avatar
Z04
funny, i have had mine on for over 4 years now and never had that happen
Old Jul 10, 2008 | 07:10 AM
  #58
hran's Avatar
hran
https://my350z.com/forum/showthread....light=dual+jwt
if that thread didnt exist i'd probably buy the JWT's....
Old Jul 10, 2008 | 07:17 PM
  #59
R-TuneZ's Avatar
R-TuneZ
well i just installed the Nismo CAI. i bought it for 230 shipped, it was not that bad price wise. i would agree that overall torque is reduced slightly, but top end horsepower is increased. if you are going 85+ acceleration is def increased, and it makes a pretty impressive sound. the reduction in low-end torque can be noticed while going up steep inclines. with this intake, your overall hp will probably be reduced, since hp is relative to torque, and being that there is a lower amount of torque in the lower rpm ranges, your average hp will suffer. i am happy with the purchase, though i am planning on seeing if i can find some way to divert cooler air into the filter. i suppose it really depends on what you are trying to do... if its just a leisure car, than i would get a CAI because the sound is very pleasing and the peak hp is increased. if you are tracking the car i would go with a sri or stock with a drop-in, to maintain your low-end torque.
i am going go out and verify everything i just said though...brb lol.
Old Jul 10, 2008 | 10:44 PM
  #60
mark88Z's Avatar
mark88Z
i have an 03 and wanted to get an 06 airbox where could i go about doing that.? and also is that the only difference between an 03-05 and an 06? would the 06 air box take my car from 287 hp to 300hp? or is the 06 hr?
