test pipes install
Old Sep 7, 2007 | 06:00 AM
silver350tn's Avatar
silver350tn
Default test pipes install
does anyone know where i can get a step by step install guide or help me out?
Old Sep 7, 2007 | 06:07 AM
blasian's Avatar
blasian
Umm, I don't know of any picture guides but it is VERY easy IMO. Only thing you need to remove from the engine back is the intake...
And from then you should practically be able to jack the car up and figure it out
Need a lot of extensions and an O2 socket.
Old Sep 7, 2007 | 08:19 AM
HondaKiller's Avatar
HondaKiller
Hardest part of the whole thing is getting the cat/test pipe on and off the headers. As mentioned above you will have to go through the top and bottom on the driver side. It's a knuckle buster, but not the hardest thign in the world. My HFC's took about 2 hours from start to finish. I was lucky enough to have new bolts connecting my headers to my cats so it wasn't too bad. If i were still running stock headers i would have had problems.
Make sure to use New bolts/washers and new gaskets to avoid having to do it again.
Old Sep 7, 2007 | 08:58 AM
Installation is straight forward:
Spray nuts and bolts the evening before with penetrating fluid.
New gaskets.
Remove oxygen sensor after removing catalytic converter. There is a special socket with a slot in the side for the sensor wire.
Old Sep 7, 2007 | 08:59 AM
Matt at PF's Avatar
Matt at PF
Vendor - Former Vendor
If you have any questions PM us or call us
matt
Old Sep 7, 2007 | 09:38 AM
failsafe306's Avatar
failsafe306
Take the o2 sensors off first. If you don't have an o2 socket, you can just use a 7/8" wrench. Then unbolt the y-pipe from the cats and let it hang. There are two bolts on each cat that you have to get from the top (engine bay) and one on each that you can get easily from the bottom. When re-installing the sensors, use anti-seize on the threads. That's about it.
Old Sep 11, 2007 | 01:54 AM
Berk_Technology's Avatar
Berk_Technology
Here you go. All the info and pictures you could want.....
Our complete test pipe manual. Also applies to our HFC's.
Right click and save as.
Berk Technology Test Pipe & HFC Manual
Old Sep 11, 2007 | 09:34 AM
failsafe306
^^ Nice write-up.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
