Got the plelum spacer installed. If driving a little bit during the day, everything is fine. If driving a lot during the day, I get this grinding sound/feel in 1st and 2nd gear from 1500rpms - 4000rpms. Anybody ever experienced this? Is this normal?
Adjust the strut bar tension so you get more clearance above the plenum.
+2 What I noticed is the more I drive the vehicle, the more the plenum expands(due to heat). It could be rubbing on the underside of your strut bar. Do you have any idling problems?
