what the difference between the Z's stock exhaust and CAT back?
Old May 25, 2003 | 05:44 PM
zogan's Avatar
zogan
Default what the difference between the Z's stock exhaust and CAT back?
I am not asking for HP numbers, asking the physical concrete difference and theory on why cat back is faster?
Old May 25, 2003 | 08:13 PM
flynnibus's Avatar
flynnibus
Z Flier
cat back just refers to an exhaust system that is complete from the cats back. Instead of just a muffler, or a piece of pipe, etc.. its the full system.. from the cat convertor back.
Why are aftermarket better then stock? More airflow, less resistance, less weight, etc.
Old May 25, 2003 | 08:50 PM
D68enny's Avatar
D68enny
The muffler is the big thing in the picture, unless you are going with a titanium exhaust, then the piping will also be super light. I don't know the weight difference on the piping between the stock exhaust and most stainless steel after markets, but I do know that most mufflers will weight about half as much as stock, and will be less resrictive.
Old May 26, 2003 | 06:31 AM
2003z's Avatar
2003z
True, however, just as big a thing is the larger diameter, less restrictive mandrel bent piping.
Old May 26, 2003 | 09:10 AM
zogan's Avatar
zogan
I saw on here that was a Ypipe for sale that would add 5rwhp w/ just the y-pipe, what are your guys thoughts on that?
Old May 26, 2003 | 09:40 AM
Ben Davis's Avatar
Ben Davis
5hp is nothing to get excited over.... I have seen cars vary 5 hp on a dyno only 5 minutes apart.... Catbacks are traditionally the first mods people make; looks, sound, power.......
Ben
Old May 26, 2003 | 11:08 AM
westpak's Avatar
westpak
SFZCC
I wouldn't just get a y-pipe, because although your freeing up the flow through the y-pipe you are going into the restrictive straight pipe, I got the Fujitsubo systm which increases the diameter to 3" of the straight pipe and also got the y-pipe that way both are increased in diameter.
Old May 26, 2003 | 12:42 PM
deeba's Avatar
deeba
isnt the stock system mandrel bent?
Ace2347
Sep 22, 2015 03:12 AM
Tylerx7z33
Sep 21, 2015 01:43 PM
FromGtoZ
Sep 20, 2015 03:41 PM
Bigsyke
Sep 11, 2015 06:19 PM
Obeorangekenobi
Sep 11, 2015 07:17 AM
