test pipe install gone wrong
Old Oct 12, 2007 | 08:42 PM
driftk1d's Avatar
driftk1d
Unhappy test pipe install gone wrong
well i finished installing my test pipes but when i rev up the engine, it sounds like the exhaust is leaking where the test pipes are as the revs come down. And i also got the service engine soon light.
I know of the rasp from the test pipe but is that what the rasp is?
I also have the non-foulers so i dont know why its throwing a code...should i just remove the negative off the battery and see if it goes away?
help please!
Old Oct 12, 2007 | 09:37 PM
Get_Zwole's Avatar
Get_Zwole
yeah its more then likely the rasp. Sounds similar to a leak. annoying but worth it in my opinion just get an exhaust thats loud enough you cant hear it .
Old Oct 12, 2007 | 11:19 PM
chadalac350z's Avatar
chadalac350z
help please!
I done this on 3 z's since you have already messed i recommend disconnect battery for 5 mins pump the brake lights to insure a complete discharge if you put on the aftermarket exhaust gaskets i would put the nissan ones back on... start car and let idle for 10 mins DO NOT rev engine up.
if this does not work post result of this.
Old Oct 12, 2007 | 11:25 PM
gsazabi's Avatar
gsazabi
You should've listened to the rasp/screeching noise my Greddy Evo2 made with TP, sounded NASTY..
Old Oct 13, 2007 | 04:34 AM
HondaKiller's Avatar
HondaKiller
even my HFC's sound like they are breathing when the RPM's are whinding down. It's normal.
Old Oct 14, 2007 | 09:33 AM
driftk1d's Avatar
driftk1d
i tried this and the light was off, but after 30 miles of driving the light came back on
Old Oct 15, 2007 | 11:52 AM
gothchick's Avatar
gothchick
First thing *I* would do is get the code pulled to make sure it really is the rear 02's (and not something else throwing the code). If it is the 02s, then try putting some stainless (pot scrubber) mesh in your non-foulers. Others have had luck doing this.
If that doesn't work, you may have damaged the 02s during the install. Time to get another 02 sensor(s). The insides of the sensors are ceramic and susceptible to damage either by temperature shock or physical impact.
Old Oct 18, 2007 | 09:22 PM
Twenty4's Avatar
Twenty4
i just installed my test pipes 2 weeks ago....service engine soon light came on after about 40 miles.....and then it turned off on its own yesterday....and has not come back on since...
Old Oct 19, 2007 | 08:20 AM
driftk1d's Avatar
driftk1d
hmm...you think mine will do that??
Old Nov 20, 2007 | 02:11 PM
Escobar's Avatar
Escobar
how the hell do you get to the top bolt on the test pipes? Do you come in from top of the motor? thanks
Old Nov 20, 2007 | 02:14 PM
aloh's Avatar
aloh
Is this "nasty" in the good way? or bad way..?
Old Nov 20, 2007 | 03:46 PM
Reality350's Avatar
Reality350
Do you have non foulers?
You can get them from "Zexy"..
Old Nov 20, 2007 | 04:11 PM
meaj82's Avatar
meaj82
edit
Old Nov 21, 2007 | 05:32 AM
gothchick's Avatar
gothchick
I was able to get to mine from underneath . But on the driver's side, I had to disconnect the steering column to get to the top bolt. I marked the steering column spline with white-out before disconnecting it, so it could be lined back up when putting it back together.
Old Nov 21, 2007 | 07:13 AM
str8dum1's Avatar
str8dum1
buy a 30" extension. no need to undo the steering column.
Old Nov 21, 2007 | 07:39 AM
tranceformer95's Avatar
tranceformer95
That's what I did. And it helps to take off the intake to reach the bolts/nuts on the driverside.
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
