Who's got aftermarket pipes, but still stock exhaust?
Old Nov 26, 2007 | 11:33 AM
Motormouth's Avatar
Motormouth
Originally Posted by Arnold K.
How's the car feel and sound with the stock stuff in the rear?
I had Headers and test pipes as a combo with the stock cat back and there was a noticeable gain in higher rpms and speeds .
the sound was good above 4k but at 2500-3000 there was nasty, nasty rasp with the test pipes (not with headers + stock cats though)
I switched to Resonated test pipes with the same headers and stock cat back and did not notice a drop in power, but the rasp was minimized and only occured from about 3k-3200 which was better as cruising rpms are in the 2s so the nasty low speed rasp was gone.
sounds mean at WOT though.
Old Nov 26, 2007 | 11:47 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I have test pipes and a Tanabe Y-pipe with the rest stock. There's rasp from 3-3.5k. It basically just makes the stock note louder. I did a before and after on a dyno with TPs and a plenum spacer. The TPs and plenum added ruffly 10 more hp to the wheels.
Old Nov 26, 2007 | 04:24 PM
SniperHunter's Avatar
SniperHunter
A reflash would have probably ailed better HP figures, imo.
Motormouth: Good, because I plan to get res. pipes, anyways.
Old Nov 26, 2007 | 06:14 PM
nathanwl2004's Avatar
nathanwl2004
Originally Posted by da mayor
you're going to get a small bit of drone on the highway
right now I have aps test pipes on a otherwise completely stock exhaust system, and no drone what so ever. I do however have a nasty bit of rasp but only at pretty much WOT.
I did notice a deffinate horse power and torque increase. however alas my stock exhaust is still far to quiet so it's time to spice things up a little bit. hense the Injen track on it's way . I'll let you know how it goes
Old Nov 28, 2007 | 01:07 PM
WTX350Z's Avatar
WTX350Z
I just installed HFC's and I retained my stock headers, ypipe and muffler section. The car sounds a little deeper at idle, but not louder. it has more of a European, rich sound (basically this mod accentuated the beautiful sound of our motor.)
I do hear a slint hint of rasp @ WOT. But nothing too bad. I need to ensure I don't have any exhaust leaks, but I'm terribly pleased. the accel does feel slightly better. I don't know how much "faster" it is. But It feels like it revs faster. doesn't seem to have hurt the bottom end.
oh and absolutely no Drone out of these cats.
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
Li1ag
Sep 28, 2015 02:07 PM
