Just dyno'd w/ Mrev2+5/16" copper iso
Old Dec 2, 2007 | 01:48 AM
Blaumph's Avatar
Blaumph
Default Just dyno'd w/ Mrev2+5/16" copper iso
So, even though I used a torque wrench, one of the 6 bolts holding down the mrev2 snapped. Took it down to Zcar garage in San Jose yesterday to have them fix the snapped bolt (which was a great experience btw, can't say enough good things about this place and Rob/Employee's). I figured I'd get it dyno'd and have them install some sways while I was there. I know it might be somewhat useless since I never got a baseline Dyno before the popcharger/mrev2/spacer. But here are the results anyways.
Max power=244.01
Max Torque=235.17
Old Dec 2, 2007 | 01:52 AM
Blaumph's Avatar
Blaumph
Btw, though the peak numbers are a little lower than I expected, the car definitely feels like it has a good increase in torque down low and in the mid/upper mid rpms. Though it does feel like I lost a small amount of power up top.
Old Dec 2, 2007 | 06:05 AM
INTIMAZY's Avatar
INTIMAZY
Nice numbers! My revup lay down 252rwhp/239rwtq on a different day-different dyno with virtually identical mods but your numbers aren't far off. Although your peak may not be that impressive... that minimum of 220tq from a bit over 2000-5700rpm is nice to have.
Old Dec 2, 2007 | 07:27 AM
singh's Avatar
singh
_______________
Hmmm...your peak hp is dipping very low.
Old Dec 2, 2007 | 09:07 AM
I like the chart except after 6,000 RPM. Is the motor running lean?
Old Dec 2, 2007 | 09:46 AM
RBlover69's Avatar
RBlover69
yea, the 5/16 lowers peak hp a bit in favor of more underneath the curve. I prefer the 1/2 spacer for a better peak.
with my previous motor on a dyno jet i dyno'd 251 std havent gotten a chance to dyno the V2 revup ..since i have no oil consumption finally. .jesus.
Old Dec 2, 2007 | 06:49 PM
Blaumph's Avatar
Blaumph
Yeah I don't know what's up with 6g to the cut off. It was also pinging quite a bit. I also don't know why the A/F isn't showing up on the chart. I assume it is running a bit lean though.
Old Dec 4, 2007 | 06:12 AM
SniperHunter's Avatar
SniperHunter
They're both supposed to offer gains from 4K and up, with the 1/2 offering an extra pony or two.
Old Dec 4, 2007 | 08:08 AM
RBlover69's Avatar
RBlover69
not the 5/16,......it suppose to provide gains mid range with a minor loss uptop , the 1/2 spacer mated with the mrev2 on the revup was suppose to provide benefits uptop while provding lesser gains mid range but both are supposed to be better then the stock setup on a revup unit.
Old Dec 4, 2007 | 10:26 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
This is true, but it's ok -- the MD spacer and MREV2 have been independantly dyno'd on MANY cars and has proven performance.
That said, I would not pay for a dyno without air/fuel measurement....
Old Dec 4, 2007 | 10:48 AM
skaterbasist's Avatar
skaterbasist
These numbers are worthless without a previous dyno or baseline dyno. They're just numbers...not comparable to anything other than someone else dyno'ing in the same exact dyno at the same time.
Old Dec 4, 2007 | 12:03 PM
SniperHunter
Oh, I suppose on a revup they'll lose a pony or two way up top. I have a 287, our curve broadens from 4.5K to redline according to some of the dynos I've read. =)
Reality350
Dec 24, 2009 06:11 PM
Reality350
East Canada
62
Jul 23, 2009 10:22 AM
Reality350
East Canada
25
Feb 8, 2008 08:41 AM
