Any DIY on installing Test Pipes?
Old Dec 9, 2007 | 10:28 PM
Mazinger Z's Avatar
Mazinger Z
Default Any DIY on installing Test Pipes?
Ok, I searched, one came up on this site on how to install headers + TP's, and on the "other site" same one. Does anyone know a good DIY on installing TP's? I seems simple but... just want a good read through before I turn myself loose.
Old Dec 10, 2007 | 05:43 AM
SuperBlack350z's Avatar
SuperBlack350z
Not sure about DIY but i can go through it with you if you need to. Pretty simple and straight forward.
Front of the test pipes,there are two bolts. The rear of the test pipes that connect ot the headers, those are three bolts. You will need a swivel with the socket up near the headers. You can use a regular wrench with the other bolts that bolt up to the y pipe. That's basically it.
Old Dec 10, 2007 | 06:00 AM
cbr900son's Avatar
cbr900son
Yeah toward the rear where the test pipes connect to the exhaust there are 2 bolts u just need to unbolt. Now the part of the pipes that connect to the headers there are 3 bolts. 1 bolt is aimed at 45 degrees toward the ground and 2 aim upward toward the engine. To make this real easy. Spray some wd-40 on the bolts and get a breaker bar. These bolts take a **** load to take off the first time. The bolts faceing the engine are easy to get to /take off if u go thru the engine bay with like 2 feet of extensions. The others are pretty much straight forword.
Old Dec 10, 2007 | 06:37 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
^+1
The first breaking lose of the bolts is tough but just knowing this beforehand makes it easier. Its no big deal.
The whole installation process is pretty easy. Takes about 1.5 hr.
Good gains.
Old Dec 10, 2007 | 07:10 AM
06MagneticZ's Avatar
06MagneticZ
I finally tried this myself. Of course I had a different set of tp's installed before so that made it a bit easier. I sprayed the bolts down with WD40. You need a 14mm wrench (easier if its a GearWrench) maybe a 14mm stubby wrench, 14mm semi deep socket, extentions, and a swivel. Maybe a breaker bar since it the first time these bolts are coming off. Good luck man.
Old Dec 10, 2007 | 07:16 AM
As members have mentioned, its pretty straight forward. Recommend that you spray nuts and blots the evening before with penetrating spray.
Old Dec 10, 2007 | 07:22 AM
SuperBlack350z
+1
There is a difference between penetrating and wd40. Water gets on the bolts of the bottom of the header so there will be rust on there.
Old Dec 10, 2007 | 09:59 AM
Mazinger Z's Avatar
Mazinger Z
^Thanks for the reply guys. For the bolts facing upwards, is it easier to go through from the engine bay? There's one you can un-do under the intake tube (driver's side), but what about the passenger side?
What about the O2 sensors? I heard that it's tough to undo, also any special care I should give it since I don't want that part to be damaged?
Old Dec 10, 2007 | 11:23 AM
SuperBlack350z
o2 sensor was easy for me. I just used a regular wrench. It's hard to strip too.
Old Dec 10, 2007 | 11:35 AM
Use a wrench like this. See the cut out on the side?
Berk_Technology's Avatar
Berk_Technology
Here's our manual. You wouldn't use our manual to install another company's products would you?
Berk Test Pipe/HFC Instruction Manual
Old Dec 10, 2007 | 11:51 AM
k6750gsxr's Avatar
k6750gsxr
its a fairly simple install..... hour... maybe 2... depends on problems taking bolts out ...
Old Dec 10, 2007 | 01:43 PM
Escobar's Avatar
Escobar
You can get them off with a long extension from the top of the bay but you really dont need to. I just took a flat wrench and took it off, takes a while but it will come off. Then when you re-install your test pipes, you will need to buy 4 bolts & nuts, the stock stuff wont work. You can also re-use the gaskets. Just make sure you spray it down with wd-40 and use a breaker bar.
Old Dec 10, 2007 | 01:46 PM
Escobar's Avatar
Escobar
that tutorial Berk supplied is really good, if you follow that you will have no problem.
Old Dec 10, 2007 | 02:33 PM
Mazinger Z's Avatar
Mazinger Z
Nice! On the manual I didn't see where you needed to use the socket extentions... was it on that third bolt facing the engine?
Old Dec 10, 2007 | 02:46 PM
Escobar's Avatar
Escobar
you just need to use it if you wanna use a ratchet to get the bottom bolt off.
Old Dec 10, 2007 | 04:50 PM
gothchick's Avatar
gothchick
+1... I have one of these... Worth their weight in gold... I got mine at Advanced Auto Parts for like 7 or 8 bucks.
Attached Thumbnails Any DIY on installing Test Pipes?-dsc02189.jpg   Any DIY on installing Test Pipes?-dsc02191.jpg   Any DIY on installing Test Pipes?-dsc02192.jpg
Old Dec 10, 2007 | 05:14 PM
skaterbasist's Avatar
skaterbasist
Installed my test pipes this weekend. The toughest part by far was breaking the bolts loose on the driver cat that connects to the header. The damn steering shaft was getting in the way. (I didn't have the 2 ft extension, so I had to get under the car to unbolt that part.)
It's not hard, just time consuming.
PS. I see you're in California. Watch out for the cops! The smell is pretty obvious.
Old Dec 11, 2007 | 01:10 PM
Escobar's Avatar
Escobar
how much is the fine?
Old Dec 11, 2007 | 01:49 PM
Mazinger Z's Avatar
Mazinger Z
Isn't it true that if they can't physically see what you have on your car, the worst thing they could do is give you a referee/fix-it ticket???
