VDC light on after headers install
Old Dec 21, 2007 | 01:16 PM
raditz's Avatar
raditz
Default VDC light on after headers install
I have just installed my Crawford headers and every time that I start the engine I get a VDC and the slip light on. I have tested it, and without cranking if I turn the steering wheel the lights come on. Of course with the engine on, the lights are also on. What can be the problem????
I also think that I have loose lots of power after the install
Old Dec 21, 2007 | 01:27 PM
SuperBlack350z's Avatar
SuperBlack350z
did you unplug any harnesses are forgot to plug them back in?
Old Dec 21, 2007 | 07:57 PM
Did you disconnect the steering linkage installing the headers?
Old Dec 21, 2007 | 07:59 PM
SuperBlack350z
with the crawford headers, i'm pretty sure he did.
Old Dec 21, 2007 | 08:04 PM
Kwame's Avatar
Kwame
On page 6 of the installation manual on their website it states...
"15. Remove steering shaft knuckle. (Make sure NOT to turn steering wheel at ALL, due to the airbag wiring cable)"
http://www.crawfordzcar.com/support/...stallation.pdf
Because if you move the steering wheel it will throw off the steering angle as far as VDC is concerned and then it goes into safe mode. Someone must have moved the steering wheel during the install.
Old Dec 21, 2007 | 08:53 PM
raditz's Avatar
raditz
So, if the problem is that the steering wheel is not at the same exact position than before, how is possible to know what is the correct possition?
During the install no one moved the steering wheel at all, but its possible one teeth jump to right or left.
If the problem is this, does the ECU run in safe mode and the performance is lower? I can say that I feel less power after the headers install
Old Dec 22, 2007 | 08:02 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Get it scanned and post the DTC code...
Rick
Old Dec 22, 2007 | 06:49 PM
VDC is sensitive to steering wheel position. Any movement of the upper or lower steering linkage may effect the steering wheel position. I am sorry but I don't know how to fix it.
Old Dec 22, 2007 | 10:07 PM
raditz's Avatar
raditz
I will do try & error, one teeth right one teeth left and see what happends. But what really disapoints me is the lost in performance that I can feel, they are Crawford with test pipes son I wasn't expecting this.
Old Dec 23, 2007 | 07:00 AM
I have little trust in the butt dyno. As with all intake an dexhaust mods, you have altered the torque and horsepower curves. You may have traded low end torque for peak horsepower.
Old Dec 23, 2007 | 09:38 AM
OCG35's Avatar
OCG35
check the A/F to determine lost power... when I added HFC I was lean and ECU was pulling timing... the car was a slug. Once A/F was adjusted I gained a bunch of trq.
Since OP has headers and test pipes A/F will be real lean.
Old Dec 23, 2007 | 11:40 PM
raditz's Avatar
raditz
I'm using an UTEC, so no there shouldn't be any timing pull
Any way today I'll make somo logs to see what happend with the AFR, because the car is slower, at low, mid and high rpms
I'm using the stock exhaust, with test pipes, and crawford headers, nothing in the intake side, and I'm using an UTEC. It's a revup engine. Really disapointed
Old Dec 24, 2007 | 09:01 AM
ISMSOLUTIONS
DTC code??????
Old Apr 12, 2011 | 07:53 PM
Shiraz's Avatar
Shiraz
Wow, Im having the same problem right now. I removed the lower steering knuckle for a header and cat delete install. Now Im getting a vdc and slip light.
Old Apr 15, 2011 | 05:12 AM
BoomerZ33's Avatar
BoomerZ33
did you notice any significant power loss? try scanning it as suggested above
Old Apr 15, 2011 | 05:16 AM
Russ@Z1's Avatar
Russ@Z1
Take it to the dealership and have them correct it if you can't do it yourself.
As said above, it's most likely the steering angle sensor.
Old May 27, 2014 | 02:28 PM
Davidopl's Avatar
Davidopl
Default i have the same problem, what is the solution?
i dont speak english so much, but i need an answer to this problem, my vdc off and slip indicators are on, all the time, i put headers on mi 350z 2003 and this problem works since 5 months
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
