Borla TD Magnaflow X-Pipe
Old Jan 4, 2008 | 02:50 PM
THE_SCHROED's Avatar
THE_SCHROED
Default Borla TD Magnaflow X-Pipe
Video after the install of the Magnaflow X-Pipe on my Borla True Dual. Just something me and Josh threw together.
http://youtube.com/watch?v=_zdm6IoS6ek
Old Jan 4, 2008 | 04:09 PM
undrgnd's Avatar
undrgnd
Okay... What are we suppose to be looking for? Sorry to tell you, but there is no perceptible audible difference in that subjective comparison. There is no way we could tell what you were doing with the throttle or how you were driving it to gage a distinction. Did it have more power?
Old Jan 4, 2008 | 04:13 PM
THE_SCHROED
No, it eliminated the rasp. There was another thread about this that I got it from, but there wasn't really any good videos. I thought I put it in the description I'll check it again.
Old Jan 4, 2008 | 09:18 PM
SniperHunter's Avatar
SniperHunter
Why didn't you opt for resonated test pipes? I'd imagine you wouldn't have needed the X-pipe if you got resonated. In any case, the video clip is great and gives you a very good idea of how much the MF X-pipe fixes.
Old Jan 4, 2008 | 11:09 PM
THE_SCHROED
I looked for a while for a good set of resonated tp's cheap but all I found was those. I didn't think that it would be as raspy as it was though. The X-Pipe def made a better sound out of the exhaust though none the less.
Old Jan 5, 2008 | 08:14 AM
CH@Dbee's Avatar
CH@Dbee
oh yeah u notice a big difference. i gotta do this.
Old Jan 5, 2008 | 08:26 AM
undrgnd's Avatar
undrgnd
I guess you hear what you want to hear. I turned up the volume all the way and the only thing I could hear clearly was how loud the passing family car was! We are comparing apples and oranges. There was no inside clip for the before, and the outside clips were filmed under different conditions as far as speed and acceleration. I'm not saying that the OP can't hear a difference, I'm saying I can't tell from that clip because there is nothing to compare against that gives me a reference point. When you try to show people how something has changed using a web clip (VERY low bit rate) you need to keep all the before and after conditions and test parameters the same.
Old Jan 5, 2008 | 08:32 AM
CH@Dbee's Avatar
CH@Dbee
when he blips the throttle at curtain times in the before and the after u notice a difference. i guess it helps if u have borla TD with test pipes and are used to hearing the rasp so as soon as u hear it u recognize it then its not there in the after part of the vid.
J_Dizzle's Avatar
J_Dizzle
southcentral>me
im glad to see you figured out the video.
but maybe we should record the after again from the same spot as before
Old Jan 5, 2008 | 09:08 AM
SniperHunter
I don't understand what's to figure out...when he pulls off the road in the before segment, you can clearly hear a butt load of rasp. When he does it in the after video, you can hear just teeeeeny bit of it, it was barely even audible.
Old Jan 5, 2008 | 02:43 PM
THE_SCHROED
I'm glad it helped some of yall that were waiting on this vid. Sorry I couldn't make it more clear, but I think all the borla owners noticed the change.
Old Jan 5, 2008 | 03:52 PM
J_Dizzle's Avatar
J_Dizzle
southcentral>me
we had trouble uploading and editing. my computer was bein a bich. not filming
Old Jan 5, 2008 | 07:26 PM
350Zenophile's Avatar
350Zenophile
I could clearly hear the difference. Great job putting that video together and congrats on no more rasp!
Old Mar 17, 2008 | 12:12 PM
pimpin714style's Avatar
pimpin714style
subscribing
Old Mar 17, 2008 | 01:02 PM
forced_04's Avatar
forced_04
schroed did you just buy the dual in/out exhaust muffler. or is there an actual muffled x-pipe
Old Apr 25, 2008 | 06:57 AM
The Captain's Avatar
The Captain
I've ordered my Magnaflow X. I'm going to do a before and after for the rasp or "rattlesnake" sound.
For those of you that want to see if it's a metal on metal sound or the rasp, take the car into 2nd gear (on AT) and go up to about 30-37 mph. It makes nasty hissing, sputtering, rattle sound that sounds absolutely horrible. Accelerate hard or shift up and the sound is no longer there.
You can see it's coming from the H-Pipe as well. All my pipes look fairly new except for the H-pipe. I have the clamp and H secured tightly, it's got this nasty brownish color right here the H pipes meet. Also, you can hear the hiss / rattle / rasp or whatever else you want to call it coming right from that area. I tested this by taking a board under the car while someone revved and putting it between my head and the back half of the car. (like a sound barrier) I kept moving around until I found the culprit, which was the H. Anyways, I'm looking forward to see how this mod turns out! Kudos to for the advice all.
Old Jun 2, 2008 | 10:34 AM
madpanda's Avatar
madpanda
Just put on my Magnaflow x pipe on the borla, and my exhaust is super quiet, you definately need test pipes, or HFC's if your gonna run this setup.
The good about this mod it kills all rasp, and I could feel a slight gain in power, but it also adds a couple of pounds.
But I have to thank The op for all the help.
Now I need some Berks.
Old Jun 2, 2008 | 10:41 AM
THE_SCHROED
Hey, glad you decided to go with the x-pipe. You should definately get some test pipes, mine has a little rasp, but not near as much as other exhaust setups. I would go with some resonated test pipes and see what that sounds like.
Old Jun 2, 2008 | 10:47 AM
The Captain
I forgot all about this thread... I've got my X-pipe in with my Berk HFCs and love it. Nice and deep (it did get a tiny bit more quiet, but that's expected with a resonated pipe). I'm especially pleased when getting on it, I can't hear any rasp at all.
The only time I hear a tiny bit of rasp is when revving, and even then you wouldn't notice it unless you were trying to listen for it. Great mod.
Old Jun 2, 2008 | 10:53 AM
Jeff92se's Avatar
Jeff92se
How are you guys installing the X pipes on your Borlas? Since the borla comes with slip fit clamps. Any pictures of the install would help ALOT!
