aem install Problems? Help!
Old Jun 11, 2003 | 07:20 PM
s2000f20C's Avatar
s2000f20C
Default aem install Problems? Help!
Buddy Installed the aem cai tonight on his sweet looking 350z. Ok install went fine but when he starts it, it kicks over for a second then stalls. Any word of advice on what might be wrong.
Maybe the mass air sensor? Any help would be great. Thanks all!
Old Jun 11, 2003 | 08:10 PM
KCZ's Avatar
KCZ
The MAF sensor is probably facing the wrong way. The section which contains the MAF should be facing toward the manifold, and the section to which the MAF is bolted should be towards the air filter. Also, the MAF sensor should be as upright as possible (it can't stick up perfectly straight or it will rub on the hood).
Old Jun 11, 2003 | 08:12 PM
suprasrule's Avatar
suprasrule
I had the exact same problem with my 90 supra, i disconected and polished the mass airflow sensor, then i hooked it back up and it didnt work, so even though the 7M-GTE is an old outdated engine the ecu tried to adjust itself to run with broken mass sensor, so the car ran fine for about 10 min but u would have to try to keep it running after that, turns out that i had messed up a flap in the damn thing when i was polishing it.
moral is do not polish it and dont **** with it
Old Jun 11, 2003 | 08:20 PM
islandsnow's Avatar
islandsnow
Default did you unhook battery?
If the Air Flow Sensor is mounted correctly, unhook the negative lead from the battery for about 30 minutes, re-attach and re-start the car, should run better.
Old Jun 12, 2003 | 11:59 AM
s2000f20C's Avatar
s2000f20C
Thanks fellas. I'll relay the info to my buddy. I'll let ya Know how it goes!
Old Jun 12, 2003 | 12:24 PM
MASTERPLAU's Avatar
MASTERPLAU
Cool thanks for the tips
thanks for the help fellas.... you guys nailed it on the mark with the mas backwards... i was tryin to finish puttin on the cai before nightfall...unfortunately, i ran out of day light, sounds ghetto right, i couldnt tell front to back... hopefully the rain will hold off, and the grill and clear side markers go on next...
peace
Old Jun 12, 2003 | 04:42 PM
s2000f20C's Avatar
s2000f20C
Thumbs up cool
Gotta love when the forums work!
Uriyo_
Sep 8, 2021 08:46 AM
