help! rasp
Old Jan 10, 2008 | 06:51 PM
JSia's Avatar
JSia
Default help! rasp
i have topspeed exhaust , stock y pipe and i just put on resonated top speed test pipes.. it sounded good FOR A good week until now.. it sounds raspy *** helll passing 3000rpm..
do u think it is the y pipe?? if it was why would it sound good for a while until now? =[
i even removed the test pipes and looked at them closer and no cracks at all.. im guessing i need an aftermarket y pipe right?
thanks for the good info
Old Jan 10, 2008 | 06:55 PM
Escobar's Avatar
Escobar
did you rev past 3k before today and hear any?
Old Jan 10, 2008 | 06:59 PM
JSia's Avatar
JSia
it had no rasp at all till today.. it sounds even more raspier than my old set of non resonated test pipes =[
JSia's Avatar
JSia
do u think it could be my stock y pipe?? cracked somewhere? its covered up in the shield so i cant really see anything but i dont think it could be it
Old Jan 10, 2008 | 07:03 PM
RBlover69's Avatar
RBlover69
i found that with a stock y pipe with my hi flows i had this annoying rasp type sound at a certain RPM. THen on a lift it was apparnt that with the diamiter of the hi flows the amount of air actually as almost being bogged by that flat thin y pipe. Trust me once you get a exhaust that will go. I have the same issue soon to be addressed.
But then again with test pipes there is a level of rasp associated with it, thats why i got hi flows but in essense that stock y pipe for sure is the cause of the sound plus maybey resonsance from the none resondted test pipes.
WHen you chose test pipes that are none resonated you have welcomed your self to rasp get resonated or hi flow next time or deal with the POWA lmao
Old Jan 10, 2008 | 07:09 PM
JSia's Avatar
JSia
but they are resonated test pipes on right now.... AND it sounded good and no rasp really at all till now.. wtf? thats wierd.. i know theres a hiss noise when having test pipes but i also have a turbo spooling noise to lol.. i think im going to put stock cats on.. and see if it will still rasp
Old Jan 10, 2008 | 07:14 PM
RBlover69's Avatar
RBlover69
i have that turbo spooling noise its the y pipe for sure when u let off betwen 2.5 k and 3k right. Its not really a turbo noise lmao but i get the figurative speech.
Old Jan 10, 2008 | 07:52 PM
phat04350z's Avatar
phat04350z
so you do not have a cat back exhaust correct?
Old Jan 10, 2008 | 08:03 PM
Escobar's Avatar
Escobar
that is odd man, I dont know how rasp can just develop...
Old Jan 10, 2008 | 08:07 PM
JSia's Avatar
JSia
i have a topspeed exhaust , stock y pipe, resonated test pipes
Old Jan 10, 2008 | 08:13 PM
phat04350z's Avatar
phat04350z
so its not a cat back because if it was you would have no Y pipe unless its not a true dual exhaust. In anycase topspeed has never been known for a borla exhaust sound. Just curious if you seeked out exhaust sounds with different things installed. Like that exhaust and an intake, or that exhaust and a downpipe. But a test pipe does allow for more air it it might be more turbulant.
Old Jan 12, 2008 | 01:02 AM
You can spend a fortune piecing together an exhaust for the “perfect sound.” Good luck.
Old Jan 12, 2008 | 04:15 AM
WalkerT's Avatar
WalkerT
Professional
The material in your Res. test pipes has cracked apart. The heat soak over the last couple days might have caused it to crack. You can pull off bad res. test pipes and shake them and it sounds like it is full of little part rattling around. Some companys use materials that are OK and might fail so if 1 out of 100 will crack they are OK with it because it is cheap to make.
Old Jan 12, 2008 | 04:42 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The cheap resonated test pipe resonators are glass packed.
The glass in your resonators was probably pulverized and blown out. The resonators are effectively gone.
Old Jan 14, 2008 | 12:49 PM
R350Zsc's Avatar
R350Zsc
just get rid of the tp's and get some high flow cats, it will fix the problem. Kinetix are good, and inexpensive.
Old Jan 14, 2008 | 01:43 PM
undrgnd's Avatar
undrgnd
^^ What he said... Elementary my dear Watson!
Since something changed over time, it cannot be a design issue. It has to be a cracked pipe or the material in the test pipes getting packed down/blown out. I seriously doubt you cracked an OEM y-pipe before an aftermarket set of test pipes. Are the flex sections intact?
z33z_nutz
Sep 23, 2015 07:22 PM
COJ_General
Sep 2, 2005 06:38 AM
NOBI
Apr 3, 2005 09:40 PM
DIE DIE DIE
Feb 10, 2005 11:47 PM
Street Visionz, Inc.
Dec 27, 2004 04:59 AM
