Which exhaust has highest pitch and least fart sound?
Thought so. What test pipes do you recommend with a nismo for that sharp sound without rasp? Also, if I'm using test pipes, is that going to affect my emission checks at the DMV? They just hook up to my ECU, not using a sniffer in the exhaust.
I have Amuse from the midpipe back and it's not high pitch at all. Pretty deep actually. I think getting the Y-pipe or test pipes is going to give you the higher pitch out of the Amuse. I'm looking to find out for myself actually.
i personally like the HKS alot too. thats what i plan on getting probably late spring or in summer. I like the nismo too but prefer the true dual. if i'm going to replace it, might as well get true dual IMO. I'm ALMOST set on the HKS, sounds, performance, and looks.
as far as test pipes, i hear the "cheaper" branded ones tend to have more rasp. and for inspection you'll need to swap in your cats unless you have a friend who can do it. i plan on going HFC, sure its more money, but its peace of mind to me, no worrying no smell of gas.
but then again this topic is mostly a matter of personal opinion. High pitched to one may sound 'fart can' to another.
good luck with your search!
Originally Posted by Kam350z
HKS has a pretty sweet high pitched sound.
Disclaimer: It sounds different under load (I'm not going to say it sounds bad, because everybody has their own opinion).
Originally Posted by texasZ350
what do you mean "under a load" ? and how does it sound different - like if you could describe it. thanks!
I am completely happy with my HKS sound.... (but I also have headers, res-tp's, x-pipe, and a good tune).
Sound is very subjective; what sounds good to me may not sound good to someone else, and visa versa.
Originally Posted by 06MagneticZ
Nismo + TP's (any tp's) = RASP.
My HKS + TP's = Sexual Seduction
Its deep at low rpm's and higher pitched at high rpm's.
