Test Pipes -- No Engine Code
Old Jan 13, 2008 | 07:06 PM
bmangold's Avatar
bmangold
Default Test Pipes -- No Engine Code
Ok, well I just finished my first mod on my car, test pipes. Installation was hell. Cat bolts were rusty and froze solid. Took me over 2 hours a full can of WD-40, cheater pipe, hammer and one broken ratchet to remove them all and the O2 sensor. About 30 minutes to get the new pipes on though.
Here is the thing, after installation I let the car idle for 5-10 minutes then drove it around the block. I was driving "spiritedly" at that for a lot of it, about 15 minutes of driving around, a little highway driving included. Got home left it idle for another 5 minutes or so while checking for exhaust leaks and ... NO check engine light! How long should it take for the code to trip? It would be awesome if it didn't but I was fully expecting an error code almost immediately.
Any body else installed test pipes w/o it tripping a code?
Old Jan 13, 2008 | 07:07 PM
mikez97's Avatar
mikez97
i havent got mine yet
Old Jan 13, 2008 | 07:11 PM
twitch579's Avatar
twitch579
Does the car feel stonger at all? Any Non foulers installed?
Old Jan 13, 2008 | 07:13 PM
mikez97's Avatar
mikez97
mine feels stronger
no non foulers atall
Old Jan 13, 2008 | 07:30 PM
Corradoslc7's Avatar
Corradoslc7
It would probably take a couple of drive cycles before any CEL's pop up.
Old Jan 13, 2008 | 08:23 PM
bmangold's Avatar
bmangold
Default No anti-fouler
No I have not yet installed an anti-fouler but I plan to.
Yes the car does pull better it seems. I get traction light kicking on in second gear at 4.5-6k rpm. I don't remember it doing that before. It feels like I gained a decent amount of mid range torque, which is what the car really needs.
Next up is Jim Wolfe popcharger and AAM angled intake spacer. When I have those installed the car is going back on the dyno so I'll let you know exactly how much power gain I am getting.
Old Jan 13, 2008 | 08:27 PM
singh's Avatar
singh
_______________
The CEL will not appear immediately. I think it'll show after 75-100 miles. Just don't get your hopes up and assume you won't get the CEL.
Old Jan 13, 2008 | 08:32 PM
singh's Avatar
singh
_______________
Originally Posted by mikez97
mine feels stronger
You don't need non-foulers b/c your AAM test pipes come with a J-pipe that extends off the test pipe. But that isn't a fix either, AAM has stated that the "fix" on their 07 test pipes do not work.
Here's how your test pipe looks:
If your CEL hasn't come on yet, it will.
Old Jan 13, 2008 | 09:04 PM
If you would like to get a SES light I can give you a few suggestions how.
Old Jan 14, 2008 | 09:58 AM
bmangold's Avatar
bmangold
Default Still no light
I took the Z to work today, 40 miles one way. Took it to lunch and drove around for about 15 minutes. Still no light. I am going to go ahead and put the anti-foulers on this week when I get time.
My test pipes are from SGP racing here in Houston. The rasp from 3-4k is really annoying, I am thinking of getting some HFC and keeping these test pipes for my twin turbo kit.
Old Jan 15, 2008 | 06:49 AM
bmangold's Avatar
bmangold
Default CEL tripped
Ok code registered yesterday on the way home. I was sitting in stop and go traffic. I need to get anti-fouler installed.
I am used to my Eclipse turbo, it would trip codes almost immediately.
I have my first question for you guys: With intake, test pipe, and angled spacer should I look into getting my ECU tuned or something like an Apexi Fuel Controller? It seems like the car would be running awful rich if I leave the stock ECU settings to determine fuel based on the O2 readings it will be getting.
Old Jan 17, 2008 | 09:59 AM
Yujimbo's Avatar
Yujimbo
so what do you guys do when it comes time to renew the inspection while the car is throwing a code?
Old Jan 17, 2008 | 02:19 PM
undrgnd's Avatar
undrgnd
You don't take it for inspection when it's throwing a code. Get the non-foulers, or whatever you need to do to FIX the reason for the CEL, then clear the codes. After several driving cycles and a few miles, the ECU will turn READY (or whatever the condition is called), and then you can take it in. After fixing a problem with the evaporative emissions cannister, I drove it 3 or 4 times for about 120 miles, and took it to the inspection station. They hooked up to the OBDII port and it passed.
Old Jan 18, 2008 | 04:02 PM
goingtopless19's Avatar
goingtopless19
i just finish intstalling my hks exhaust, and the non foulers for the test pipes that i put in last week and so far i put about 100 miles on the car so hopefully i get lucky but the guy at nissan said that there is no fix and you will threw the light everytime until a reflash comes out for the ecu but in the mean time my 07 is so much more fun lol the exhaust with the test pipes is so loud and you can feel the difference.... to get a video i need two things
1. a video camera but im sure i can get one easily
2. a how to on how to put it on here so if neone can take the time out i would really like to try and get a video so please help.
Old Jan 18, 2008 | 05:00 PM
undrgnd's Avatar
undrgnd
I'll tell you what I do for both pix and videos.
Get a free account at Photobucket.com.
Upload your video to Photobucket.com.
Copy the link of your video at Photbucket.com
Paste the link in your post.
Done.
Old Jan 18, 2008 | 08:29 PM
singh's Avatar
singh
_______________
What test pipes you get?
Please tell me they were resonated test pipes! I'm looking to hear that setup!
Old Jan 25, 2008 | 03:06 PM
JDub03's Avatar
JDub03
so non-foulers are the problem solvers to the SES light? for how long? and where can these be purchased? i put my test pipes on monday and got the light today. stillen test pipes
Old Jan 29, 2008 | 07:59 PM
mikez97's Avatar
mikez97
it just did today
Old Jan 29, 2008 | 08:11 PM
singh's Avatar
singh
_______________
...If your CEL hasn't come on yet, it will.
it just did today
Old Feb 9, 2008 | 12:02 PM
djscotty's Avatar
djscotty
quick question when the car throws the CEL, does it hurt the performance of the car with the CEL on or does it not matter the car is going to run the same. Reason y im asking is y would you put test pipes on when its going to hurt the performance of the car? Thanks
