plenum spacer question??
Old Feb 5, 2008 | 09:53 PM
dexwtzrllygud's Avatar
dexwtzrllygud
Default plenum spacer question??
will a skunk2 1/2" spacer clear the oem bar on my z? Will the engine lose throtle response because the spacer is so big?
Old Feb 5, 2008 | 10:18 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
buy a motordyne 5/16 spacer they are proven power makers and you can still retain factory strut bar, Tony is a awesome guy and his handle on here is hydrazine.
Old Feb 6, 2008 | 02:43 AM
ZTUPID's Avatar
ZTUPID
I'm running the 1/2" spacer. It does not clear the factory strut bar. Throttle response is crispy as ever. What other mods are you running?
Old Feb 6, 2008 | 04:30 AM
dexwtzrllygud
Thanks for the feedback guys.. The reason y I was asking was because I was getting a spacer for 60$ .. But I wasnt sure if it would work.. Right now the car is stock because I just got it.. I see that the spacer is the best bang for the buck with power so I'm trying to do that first..
Old Feb 6, 2008 | 04:32 AM
phreaktor's Avatar
phreaktor
Design Engineer
Do you need an installer?
Old Feb 6, 2008 | 04:54 AM
Reality350's Avatar
Reality350
LoL!
at $50 /hour?
Old Feb 6, 2008 | 05:02 AM
dexwtzrllygud
na thanks guys but it looks pretty straight forward..
Old Feb 6, 2008 | 05:12 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
i have a motordyne 5/16 spacer which was my first mod on my Z and i loved it. its very easy to install you dont need to give it to someone to do it just open up the plenum put the spacer in and you're done. if you want you can clean out your plenums as well but motordyne one is a great buy and definately better than skunks spacer.
Old Feb 6, 2008 | 05:13 AM
Reality350's Avatar
Reality350
It is.. even I could do it
Seriously though, just torque them down properly and in the correct manner and you should be good to go.
Cant go wrong for $60 I guess. I personally spent the extra cash for the Motordyne products. You cannot get any better customer service, IMO. Tony is top notch.
Old Feb 6, 2008 | 05:24 AM
What does Skunk say about the OEM bar?
Old Feb 6, 2008 | 05:41 AM
dexwtzrllygud
i think ima just end up buying a motordyne.. i havent called skunk .. i was just asking bcuz i thought it wasnt a bad deal if the fit was correct.. thanks guys i will defenetly look into a motordyne.. any one have one laying around that they wanna get rid off? lol
Old Feb 6, 2008 | 05:51 AM
Welcome. Independent spacer testing was done about 3 years ago. Check the Motordyne site for results.
jcleary47's Avatar
jcleary47
When you say torque them down properly, are you required to use a torque wrench with a specific setting, or do you simply mean be smart about tightening it back up and not overdoing it?
Old Feb 6, 2008 | 06:29 AM
VisionaryRacing's Avatar
VisionaryRacing
We have the Iso Thermal Spacers in stock, and you are free to pick up or we can have it shipped out immediately.
You can get away without using a torque wrench if you are fairly handy and can gauge your strength, however I would still recommend getting a torque wrench. It is a great tool to have and it is also very reassuring to know what each bolt is the exact torque as the others. Some of the bolts can snap very easily so it is bad to over torque, and of course if you under torque you will have leaks.
Old Feb 6, 2008 | 06:37 AM
DanielW's Avatar
DanielW
motordyne 5/16 iso thermal spacer FTW
Old Feb 6, 2008 | 09:15 AM
gothchick's Avatar
gothchick
+1
That's what I have. That and an MREV2 (for revup's). Highly recomended.
Old Feb 10, 2008 | 01:41 PM
AdamEmileC's Avatar
AdamEmileC
i herd that the spacer does not give much gains for the 07 z's is that true???
Old Feb 10, 2008 | 02:59 PM
ladyzed's Avatar
ladyzed
True - because of the redesigned plenum and nature of the new VQ35HR. =)
Old Feb 11, 2008 | 07:41 AM
zbrid's Avatar
zbrid
I got the motordyne 5/16 spacer, It was easy to install, & when I took the upper plenum off I sanded it down & buff it out! Now it looks great & sounds great!!
issyz
Jul 2, 2017 03:04 PM
