Heat Wrap/ insulate the intake tube?
Old Feb 12, 2008 | 07:39 AM
T_K's Avatar
T_K
Originally Posted by gothchick
It would, but I doubt it will be enough to compensate for the fact that there isn't any air moving through the engine bay.
Not much different than a dyno.
TK
Old Feb 12, 2008 | 07:43 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Here is the correct stuff I got!
http://store.summitracing.com/partde...rt=THE%2D13575
Old Feb 12, 2008 | 08:02 AM
djtimodj's Avatar
djtimodj
I have heat rapped my K&N typhoon with DEA heat reflect tape!
Did the intake tube and all the air box.
Before after driving i could not keep my hand on the air box and the intake tube was realy hot to.
Now after the heat rap its only just warm! result! lol..
Airbox
Intake tube. Its the best pic i have sorry.
Go for it mate!
Old Feb 12, 2008 | 08:16 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by T_K
Wouldn't just holding a constant rev before launching replicate the cooling effect on the MAF from air flow?
TK
That's definitely the right idea, and I tried that too, but partial throttle (with the clutch in) just doesn't have enough air flow compared to WOT under load.
You really need to slam the throttle to get it to cool down in any reasonable amount of time. But then there is a drawback to that too....
If its enough reving to cool down the intake system, its also enough to get the engine hot. And hot engine coolant also reduces engine power too... So there is a balance that needs to be maintained. Sustained reving of the engine before a dyno pull isn't good either.
The best solution was to simply wrap the intake.
Old Feb 12, 2008 | 08:30 AM
gothchick's Avatar
gothchick
Originally Posted by SOLO-350Z
Before you purchase let me get the right link tonight at the house. I won't be home till after 9 though. The pieces I got were much bigger than that.
Will do.
Edit - just saw your update. Thanks for the help~ :-)
Old Feb 12, 2008 | 08:47 AM
chamois's Avatar
chamois
Airbox
Go for it mate!
djtimodj, What kind of wrap did you use? did you use this, http://store.summitracing.com/partde...rt=THE%2D13575 ? if so how much would i need? i have a K&N typhoon also. thanks
Old Feb 12, 2008 | 09:11 AM
gothchick's Avatar
gothchick
I just ordered this for the straight part of the intake tube:
And this for curves, bends, and odd shapes (like the MAF sensor):
http://store.summitracing.com/partde...5&autoview=sku
I think I'll try to insulate the airbox as much as I can too.
Old Feb 12, 2008 | 09:28 AM
onyxaltezza's Avatar
onyxaltezza
Thats why you get MSD 2STEP. =D That thing is sweeeeeeeeet, especially if you're boosted....some people claim its the best $400 they ever spent AFTER boost and tuning costs...
Alright you guys can try out what you want...but we've tried it on the dyno on IS300s and got freakn heatsoak. What would actually be more effective is not to wrap the pipe, but as shown in the pics, either get a heatshield, or warp your current one. That would provide much better cooling that just wrapping up a pipe...
-Aaron
Old Feb 12, 2008 | 09:31 AM
gothchick's Avatar
gothchick
Just ordered a turbo blanket to wrap my stock airbox in:
After fully heat shielding the entire intake, I wonder how much the air heats up once it's in the plenum? I have a thermo gasket between the lower collector and the engine, but the engine bay heat will still soak through the plenum itself... Maybe I should also wrap the plenum assembly in a turbo blanket too~ Jk Lol! :-)
Old Feb 12, 2008 | 10:12 AM
onyxaltezza
What you guys really need is Meth/Water injection if you wanna cool intake temps enough to make a diff =D lol
Old Feb 12, 2008 | 01:35 PM
djtimodj's Avatar
djtimodj
60ft dit what i used to do the intake tube and air box mate!
Old Feb 13, 2008 | 12:32 AM
DRELOC's Avatar
DRELOC
djtimodj, did u powdercoat your plenum cover black? I like it!!
Old Feb 13, 2008 | 06:09 AM
taurran's Avatar
taurran
On the stock plastic intake tube it might help a little, as the plastic doesn't conduct heat like aluminum CAI piping will do (the OP asked about on a CAI). As far as aluminum piping, I'll just say that any sort of insulation works both ways. You're just trapping heat IN the pipe with heat wrap because it's already heated from direct contact points with the motor.
But really, I wouldn't expect to see much of a gain anyway. I guess it's a matter of perspective and anything less than 5whp isn't really worth the amount of work invested. I mean, at most I would expect you to maybe see a difference of 1-3whp peak on a 2nd+ dyno pull. It would make very little difference on the street.
I'm always amazed to see the lengths the NA folks on this forum go through to gain 1whp.
Old Feb 13, 2008 | 07:04 AM
T_K's Avatar
T_K
Although ridiculous at times, one could also argue that, the 1hp gain is what its all about.
TK
Old Feb 13, 2008 | 07:14 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
On test results that me and a few others have done by wrapping our intake tube and intake boxes, we saw a drop of 30 degrees.
Old Feb 13, 2008 | 07:30 AM
sloppymax's Avatar
sloppymax
just curious at what contact that drop occured? were you monitoring the AIT located in the maf or using an infrared thermometer?
Old Feb 15, 2008 | 03:27 PM
chamois's Avatar
chamois
for those of you interested in this, i just wrapped my k&n typhoon intake and intake box with the heat reflecting tape. drove like 40 min on the high way then came back, the intake and box were much cooler than usually are. thought it worked well. who knows about hp though. maybe 1 or 2?? idk
Old Feb 17, 2008 | 01:26 PM
  #38
gothchick's Avatar
gothchick
Just wrapped my intake and air box. After watching IATs before and after the mod with Cipher, I noticed no appreciable difference in intake temps while the car was moving above 30mph.
However, while stopped at a trafficic light or being stuck behind some slow-@ss grandma in a minivan, I noticed my AITs were 15C to 20C cooler with the intake & airbox wrapped!
A cool inexpensive mod. :-)
Attached Thumbnails Heat Wrap/ insulate the intake tube?-dsc02270.jpg   Heat Wrap/ insulate the intake tube?-dsc02271.jpg   Heat Wrap/ insulate the intake tube?-dsc02272.jpg
Old Feb 17, 2008 | 01:30 PM
  #39
jonnylaw's Avatar
jonnylaw
^^Sweet. Looks like u did a good job with it too!
Old Feb 17, 2008 | 01:48 PM
  #40
gothchick's Avatar
gothchick
Thanks Jonny! The air box was a little awkward to wrap cause of all the odd shaped corners and such... But it's really no harder than wrapping x-mas presents~ Lol! :-)
