Heat Wrap/ insulate the intake tube?
Originally Posted by gothchick
Just wrapped my intake and air box. After watching IATs before and after the mod with Cipher, I noticed no appreciable difference in intake temps while the car was moving above 30mph.
However, while stopped at a trafficic light or being stuck behind some slow-@ss grandma in a minivan, I noticed my AITs were 15C to 20C cooler with the intake & airbox wrapped!
A cool inexpensive mod. :-)
It typically takes about 8 more seconds to cool down when its not wrapped. And due to the ECU's change in timing that means somewhere around 5-10 HP lost for that first 8 seconds.
Its not earth shattering but its there. For dyno testing and drag racing its worth doing.
I just ordered this for the straight part of the intake tube:
http://store.summitracing.com/partde...rt=THE%2D13575
And this for curves, bends, and odd shapes (like the MAF sensor):
http://store.summitracing.com/partde...5&autoview=sku
I think I'll try to insulate the airbox as much as I can too.
there was a thing in import tuner mag last month about a water/meth cooled intake wrap. i agree the idea is good, but would this thing really work??? it looks to me like a turbonatorish item
Originally Posted by Frostydc4
Just curious, how many quanties (if you ordered more than one of each) did you order. I'm about to place my order and I want to know how much I should buy. Thanks.
I don't have any gripes about the heat wrap other than the adhesive doesn't stay completely tight. So you'll need to add a few zip-ties to keep everything snugged up.
the thing i saw looked like a coil cooler wrapped around the intake tube. i will try to find pics of it. just curious if this thing would even work....more curious of if it would actually work than interest in buying it.
the new ARC heat fins seem to work if theyre wrapped on the intercooler piping. they tested it on an Evo, put the fins on the pipes on either side of the intercooler...dropped intake temps.
it was called the S-max ice tub: http://www.speedmaxperformance.com/
it takes a CO2 cooling system and wraps the intake tube in an aluminum tube that CO2 will run through. they claim it can be used as an intercooler on turbo system. interesting, but not so sure about it.
Originally Posted by joe645733
youre not building big amounts of heat, you dont need to heat wrap your intake tube lol...
thats being a little over the edge. ur car will look like pure rice.
Not sure who's car this is, but it looks like he used header wrap on his intake.
Originally Posted by Dave 90TT
You apparently haven't opened the hood after a 20 minute track session and felt the immense amounts of heat underneath the hood.
Surely I'm not the only that has noticed that these motors are extremely consistent on the strip regardless of how hot or cold the motor is. I've tested my G at the strip (same days) with hot laps (3 back to back runs) and then letting the engine completely cool and making a run immediately. With the same 60 foots within 0.05 seconds, the ETs are within 0.05 seconds and MPH within 0.5mph. I have a very hard time believing that wrapping the intake is going make a huge difference in keeping performance consistent.
It was worth it to me personally seeing the IATs go down... Cooler intake temps help combat knock, which helps you run a more aggressive tune. But to each their own.
Of coarse if you *really* wanted to lower intake temps, water/meth injection would be the way to go...
