Side exit exhaust on a Z
Considering what everyone else has said.......I am going to say the same thing. Don't do it! Is is really necessary? The rear of the Z looks so nice with the twin pipes. Just get an HKS aftermarket exhaust and put that *itch on there!
Originally Posted by s3fddiZ
I would say the reason to go side exhaust is for uniqueness. What about going center exhaust like stillen?
Ya, this is exactly why I am doing this!! I would like to do center exhaust but its way too expensive.
Side exit is a good way to differentiate from all the other z's. If i roll the rear bumper and make the side exit look good then it would make my Z look a little different.
Originally Posted by calin
you might need some parts overnight from japan
ohhh and get NOS too!
you can do some mods like the guys on here do and set yourself apart from 90% of the Z's out there with fatass ex-soccer moms behind the wheel and make yourself look good.
there are tons of guys on here with the LMGT4's but I've yet to run into another Z running the Nismos, and I'm using pretty stereotypical equipment here.
there are a million ways "unique" can go very, very wrong.
golf clap for S3...ya gank the shot of a side exit off a viper or somethin? it could look good with some fairly extensive (by my lazy *** standards) fabrication...not worth it at all imo unless you have alot of other stuff done and youre showing the car and you want a super cool carbon fiber underbody diffuser/vortex generator out back instead of exhausts.
Though I have not tried this on my NZ, I did own an 05 Mustang which came from the Dealer with side pipes. After the left side pipe got bent backwards for the second time due to hitting a manhole cover that was slightly raised, I decided to revert to dual rear pipes. I personally strongly advise against it, having had the experience. On a positive note, the sound was awesome and the ladies loved the vibrations under the seat. Of course it is your call, but I strongly encourage you to put a lot of thought into it.
might not look too bad.....
note: my photoshop skills are slightly above those of an infant....
Originally Posted by go-fast
you would have to notch the gas tank....probably not the smartest way to route the exhaust.
http://s3.photobucket.com/albums/y92...=350zgt3-2.jpg
Here's a picture of what the side exhaust looks like on my GT3 spec 350Z sillouette racer. Keep in mind it's a purpose-built tubeframe race car. The exhaust came out that side because the plumbing and layout of the chassis allowed it. Not the same for a production FM-platformed car like the Z.
This car uses SR20VE power and the exhaust is loud enough (even with a Magnaflow race muffler) that you need earplugs to avoid hearing damage when driving it. More details can be found under 'project vehicles' at: www.nissansportmag.com
I was surprised nobody mentioned it but I think the op should stray away from what has already been done (jun side exhaust) and go all out with some stackers!!!! Maybe in his case don't even let the pipes go all the way through the top just flip them up into the cabin and break the power window/door switches...
Originally Posted by dave079
Function > looks in that aspect
I am sure they werent doing it for show.
i totally agree... but as for someone doing it for show... which is why i think the OP wants to do it... it looks like shat.........
