SSV vs Plenum spacer / upper plenum
Old Feb 17, 2008 | 02:55 PM
supra crazy's Avatar
supra crazy
Default SSV vs Plenum spacer / upper plenum
Hey guys, today I was talking a friend who claims a SSV plenum adds 50whp on a FI car. He also believes that plenum spacers, and upper plenum's (APS tall boy , crawford) don't add power, but only increases lag "because they increase the volume of the plenum" ... I'm trying to tell him who ignorant and dumb he is for not doing any research on this topic. He swears by it and says not only will it add 50whp but its uber cool for nitrous.
Please post some of your own opinions so this kid could be somewhat less of a ****tard.
Thanks
Josh
zcon's Avatar
zcon
lol your friend seems like an idiot who hasnt done any reseach. he should probly just jump off a high location and throw in the towel
Old Feb 17, 2008 | 10:54 PM
G35Rider92649's Avatar
G35Rider92649
+1 What an idiot, SSV is a joke hahaha
Old Feb 18, 2008 | 04:36 AM
lemans350zr's Avatar
lemans350zr
Posted here by someone else.
The SSV is known for not being a good intake manifold because of its cost and the various people who have reported power losses with it has spread like wild fire overshadowing the people the SSV has gained power for. However I think there is a pattern to the people who have lost power and the many people who have actually gained power.
I think you'll find that people who have upgraded their cams and/or headers, and/or ported/polished their heads and then a tune have all had good results with the SSV. The people who have lost power or haven't noticed a difference all have the stock heads, cams, and exhaust manifolds or small TT exhaust manifolds.
The idea is, if the engine can't get the air out easily enough through the actual engine itself, the SSV will lose power.
This also has applied to all sorts of other engines
http://www.vetteweb.com/tech/vemp_07...old/index.html
Rather, the intake-manifold-runner lengths must be tuned to work in conjunction with the cam profile, the head-flow numbers, and even the primary-tubing diameter of the exhaust. Failure to tune runner length will result in less power rather than more, regardless of the airflow numbers of the ports themselves.
Some other articles/write-ups that support this are
http://headerdesign.com/extras/engin...take_Manifolds
http://www.wighat.com/fcr3/engine.htm
http://www.team-integra.net/sections...sp?ArticleID=2
These people all have cams and/or headers, and/or port/polished heads and have all gained power or at least felt they gained power with the SSV.
vortech, alphawerks headers
gained power from 4500 to redline
would have gained more power across the whole powerband if tune wasn't 2 pts too rich
https://my350z.com/forum/showthread....;highlight=ssv
vortech, stillen headers
gained power
https://my350z.com/forum/showthread....&highlight=ssv
vortech, cams and headers
did some minor mods and gained power all over the powerband, feels the SSV helped
https://my350z.com/forum/showpost.ph...;postcount=112
TN kit, built long block, ported heads, JWT cams
gains all over the powerband
https://my350z.com/forum/intake-exhaust/143573-kinetix-ssv-dynoed-n-a.html
vortech, DC headers
lost power above 5500 rpms, however was way too rich there - possibly inconclusive?
gained power between 2200-3000 rpms - just needed to lean out A/F there back to normal
NA, Tomei 268 cams, crawford headers
felt a gain in power
NA JWT cams, crawford headers
felt like a gain in power over crawford plenum
https://my350z.com/forum/showpost.ph...mp;postcount=8
topspeed headers
felt a gain over kinetix V4
FI with cams
feels the SSV is a little better than the V4 plenum
https://my350z.com/forum/showpost.ph...p;postcount=34
him and his mechanic also believe the issue with letting an intake manifold flow more has to do with how well the air can flow through the heads
I also had a very long chat with my mechanic about plenums and such. He has built an 11.0 sec car from an old Corolla 4 cylinder (this would run 10 or lower in the US) and did all the mods on my car so I guess he knows what he's talking about. He basivcally told me that we can do what we want to our plenums, but at some point it will not improve anymore. Once the plenum is 100% efficient/big enough/flows enough/etc (*)... the real bottleneck is below the plenum. The valves and the intake ports are still restricting airflow so you would need to port the intake ports, go for a bit bigger valves. Would be nice to know if something like this was done to the car with that enormous HP gain...
TT, built long block, cams
gained 17 lbs tq, 26 whp with SSV
These cars lost power with the SSV and they all are running the stock heads/cams with stock exhaust manifolds or smal TT exhaust manifolds. I'm sure there's quite a few more people who have reported losses with the SSV, but from doing my own extensive searching, these are the people I've found who have reported losses.
NA, stock engine, stock exhaust manifolds
no gains felt and no faster 1/4 mile times
APS TT stock engine, small APS exhaust manifolds
power loss
https://my350z.com/forum/showthread....;highlight=SSV
vortech, stock engine, stock exhaust manifolds
lost 10 tq in midrange, top end hp stayed same
https://my350z.com/forum/showthread....ghlight=ssv+10
post #64
SSV lost power
https://my350z.com/forum/intake-exhaust/208880-kinetix-plenum-shoot-out-stock-car-plus-more.html
APS single turbo, stock engine, stock exhaust manifolds
22 hp lost
JoeDirtPharmD's post near bottom of page on
http://www.az350z.com/forum/viewtopi...&highlight=ssv
I have also come across two people with stock NA engines without headers who posted that they felt a gain in power with the SSV and 2-3 NA people with stock NA engines without headers who said they haven't noticed a difference with it.
For turbo cars, think about the turbos being right there blocking some of the airflow right at the exhaust manifold. Sure the exhaust probably flows great after the turbo, but this would add further evidence why turbo setups lose power with the SSV by having the restriction put so close to the engine itself
Old Feb 18, 2008 | 05:37 AM
gothchick's Avatar
gothchick
Somebody on this board had to reweld a broken intake runner weld on their SSV. They were boosted though...
Old Feb 19, 2008 | 02:46 PM
supra crazy
Thanks for the input i do realize that a SSV on a motor that has cams and head work would add power but that isnt what I was asking this moron kid think is it will add 50whp on a bolt on FI car with a tune and you will not gain any power if you get a spacer or an different upper plenum, you will only increase lag.
Old Feb 19, 2008 | 07:06 PM
undrgnd's Avatar
undrgnd
Why do we have to tell you anything? Your friend would believe a total stranger on the internet but not you? You must be a really reliable fellow. Why don't you search yourself and find the benefits of APS and Crawford uppers, which are similar to spacers. Check out the Motordyne website. There are plenty of dynos and comparative data on there, and if that's not good enough, none of us really give a shiet what your 'friend' says.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
