MD Plenum Spacer install problem
Old Mar 5, 2008 | 11:46 AM
  #41
Yujimbo's Avatar
Yujimbo
i know mine has one the guy told me he installed it. he just didnt show me where it was... where is it suppose to be?
Old Mar 5, 2008 | 01:31 PM
  #42
Eazzy's Avatar
Eazzy
I dont use them but I believe they are located on the drivers side of the motor
Old Mar 5, 2008 | 01:37 PM
  #43
Yujimbo's Avatar
Yujimbo
alright ill check it out when i get out of work tonight.
Old Mar 5, 2008 | 04:28 PM
  #44
dmroberson's Avatar
dmroberson
Originally Posted by Yujimbo
that sounds about right. it was about 40-50 degrees outside. So i need to close it when its cold right. I read the manuel but i had a shop put mine on and I dont know where the actual valve is... I know I know you dont have to call me retarded i already know. lol
No, you open the valve when it's cold out. You close it when it's warm out, for max performance.
Eazzy is correct. It's on the driver's side. Look under your intake tube. You should be able to see/reach it from there. When the lever is perpendicular to the valve, it is Closed. When it runs parallel, then it's Open.
Old Mar 6, 2008 | 05:29 AM
  #45
Yujimbo's Avatar
Yujimbo
found it and ya that was the problem thanks
Old May 14, 2008 | 02:49 PM
  #46
jmccartney's Avatar
jmccartney
I installed the 5/16" spacer and it runs like a champ. Quick question. I didn't install the stock upper plenum gasket that is a huge piece with the baffle gasket attached? Is this an issue? The instructions say it works either way. I just want clarification. Thanks!
Old May 14, 2008 | 03:03 PM
  #47
CSF's Avatar
CSF
i didn't install it either...if the instructions says it's ok and it's running fine, you should be good to go
Old May 14, 2008 | 03:20 PM
  #48
jmccartney's Avatar
jmccartney
cool thanks for the update man!
Old May 14, 2008 | 05:31 PM
  #49
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Technically, its not good to have more than one gasket, but in practice, its never been a problem. So it comes down to personal preference.
If you were leasing the car or planned on selling it in the near future, you can keep the stock gasket in there with no problem.
That way when you turn the car in or sell it, all you have to do is take out the spacer and the stock gasket is already there to seal against the stock upper plenum.
You can sell the spacer pretty easily online and get a good portion of your money back.
Old May 14, 2008 | 07:31 PM
  #50
sukebe's Avatar
sukebe
Originally Posted by Asian Invasian
I just installed my plenum spacer today and ran into some problems. After I had put in my spacer in and put the top peice back on I was screwing in the final screws to wrap up my installation. When screwing in the bolts tightly some of them would all of a sudden come lose again. So I would tighten it but it wouldn't stop it keeps going but its not tightening, this happened on a couple of my bolts.
I didn't know how much it was going to affect the air coming into my engine so I started it up and idle and everything is fine. I took it for a test drive and when i punch the gas i can hear a loud squeek which I am sure is because of the screws not tightening for some reason.
What am I supposed to do, it doesn't really make sense to me why it wont tighten.. :/
I find it funny that your avatar says, "STFU NOOB!!!"
Old May 26, 2008 | 07:43 PM
  #51
Spoiled Z's Avatar
Spoiled Z
I broke off the CCV grrr its a b*tch to screw it in. I'll see if home depot has em.
Old May 27, 2008 | 06:07 AM
  #52
Chef-J's Avatar
Chef-J
Booooosstt!!
LoL
Old May 27, 2008 | 07:07 AM
  #53
Hydrazine's Avatar
Hydrazine
Just tighten the threaded brass horse barb fittings down with enough to torque to make a seal with pipe thread putty. It doesn't need a whole lot of force.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
