HFC-Nismo Y-pipe-OEM
Old Mar 12, 2008 | 10:08 PM
Sunset350ZR's Avatar
Sunset350ZR
Default HFC-Nismo Y-pipe-OEM
Ok I have a set of metallic HFC and will shortly have a Nismo Y-pipe. Now I know that the Y-pipe of the Nismo is greater in size than the midpipe but how much power am I going to lose by going from Berk HFC to Nismo exhaust to oem mid pipe and muffler? Also will it cause any proplems in upper rpm ranges besides loss of power? I assume no but not sure. For everyones eae of mine I intend to change out the midpipe and mufler as well when excess play money comes around.
Old Mar 13, 2008 | 01:09 PM
Sunset350ZR
Does any one know the approximate weight for a Nismo y-pipe?
Old Mar 13, 2008 | 01:54 PM
singh's Avatar
singh
_______________
Let me get this straight. So you have a Berk HFCs and Nismo y-pipe and want to pair it with OEM mid-pipe and muffler?
I see no problem with that setup. You will not lose anypower, I think the OEM midpipe diameter is somewhere between 2.75-3.00". If I recall, Nismo y-pipe has a 3" collector. I seriously doubt you will lose any power with your setup.
Old Mar 13, 2008 | 02:05 PM
Sunset350ZR
Most likely I will change he rear as well but not yet.
Old Mar 13, 2008 | 05:52 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The stock piping beginning from the merge (from the 2 inlets of the y-pipe) is 60mm (~2.36"). Most aftermarket exhausts are 76mm (~2.99") beginning from the same collector (where the 2 inlets merge on the y-pipe). Some, like the JIC y-pipe, are 80mm (~3.15") in diameter. Others, like the Tanabe y-pipe, have the 70mm (~2.76") diameter.
Old Mar 13, 2008 | 07:46 PM
Sunset350ZR
So can I assume that it will not make any more power either? Would you expect the sound to be any different?
Old Mar 13, 2008 | 08:15 PM
3hree5ive0ero
Retired Admin
Take it from somebody who actually has this set up (very similar). You do not make or lose much power compared to stock exhaust with HFC. The sound is similar to that of the one with just the HFC. There's nothing to worry or stress about. These are minute differences.
BTW, look at the pipe sizes I posted above yours for the correct sizes.
Old Mar 14, 2008 | 05:35 AM
singh's Avatar
singh
_______________
It would be a guess at best to say whether or not you are losing horsepower. The only way to prove it would be to strap it to a dyno and do before/after dyno runs. Which, IMO, would be completely pointless.
But like the moderator said, these are minute differences, nothing you should be tripping over.
$100 says you won't lose any horsepower.
Old Mar 14, 2008 | 05:58 AM
Sunset350ZR
Thumbs up
Not worried about the power really that was just curiosity. Since my feelings that no harm from more flow to reduced flow was confirmed the rest is purely for information.
Thanks to all who posted.
Old Mar 14, 2008 | 11:38 AM
3hree5ive0ero
Retired Admin
What's with you and betting all the time?
You still owe me and that one dude (who I helped out) $100 each.
Old Mar 14, 2008 | 07:29 PM
singh's Avatar
singh
_______________
Lol. I just got 68mpg, I need to upload the image so I can prove you wrong...again.
