JWT Pop Charger + 350Z = Car Turning Off Every Other Day
Old Mar 19, 2008 | 06:46 PM
BornSlippyZ's Avatar
BornSlippyZ
Originally Posted by nothix
Get a K&N recharge kit and clean the filter correctly.
Get some MAF cleaner and clean the MAF correctly (isn't cheap to replace).
This should help out a lot.
I agree,,op could have oiled the Pop charger too much and oil got on the MAF.
Old Mar 19, 2008 | 06:47 PM
Escobar's Avatar
Escobar
I think your filter being very dirty is probably the culprit. My Z has died on me a couple of times when I rev out above 4K or so and then press the clutch in as well. Im not to worried about it, I think its fairly normal as long as it doesnt happen often.
Old Mar 19, 2008 | 09:13 PM
miked1331's Avatar
miked1331
Hope you didn't suck up a june bug
Old Mar 19, 2008 | 09:32 PM
black06z's Avatar
black06z
Just take that junk off and put back the stocker.
Old Mar 20, 2008 | 08:05 AM
ed350's Avatar
ed350
wow.. thats dangerous shut off when going high speed...did anyone call the manufacture up and address this issue..
Old Mar 20, 2008 | 08:16 AM
ke0ki2k's Avatar
ke0ki2k
I'm pretty sure this is normal problem...they heatsoak easily and it'll kill the engine if you throw it in neutral and the RPM's crash too fast. try cleanin the filter and clean off the MAF. do you have the heatshield installed (not that the JWT heatshield does much)?
Old Mar 20, 2008 | 09:18 AM
kenpo_350Z's Avatar
kenpo_350Z
Originally Posted by On Nightfall
Hey kenpo 350Z, I would recommend you get the pop charger. Like you said, just make sure the clamp is very nice and tight and you push the filter as far back as possible. Other than this which was my bad, I’ve never had a problem with it and it sounds great! No Filter = Max Air Flow LMAO! Had me laughing nothix.
Thanks I will keep that in mind when I get to looking. Its between the JWT and short ram K&N.
Old Mar 21, 2008 | 09:51 AM
The Closer's Avatar
The Closer
Mine hasn't done anything like that and I've been using the JWT for 6 months now. Never once wanted to turn off. Haven't cleaned the filter yet either.
Old Mar 21, 2008 | 09:25 PM
35oZephyR's Avatar
35oZephyR
Call me stupid but I checked under the hood today and the intake filter was completely off. I had checked after the first time it happened but it was at night so maybe it was really loose and I did not notice. I'm sorry to have wasted your time guys but you had great suggestions and speedy responses. THANX!!!
P.S. I hope the engine didn't suck in anything while it was off. =(
Had the same exact thing happen to me. I guess the vibration will loosen up the filter if you don't firmly tighten it to the collar during the initial installation. I just bolted the whole Intake to the tube and thought I was good to go.
Old Mar 24, 2008 | 04:25 PM
eduke23's Avatar
eduke23
Originally Posted by kenpo_350Z
Well at least that gives me some more confidence in getting the JWT. I will just be sure that mine is secured.
Same here, now I feel a bit more better about ordering one. This problem could be serious if it affects me, but what intake would everyone recommend?
Old Mar 25, 2008 | 05:56 PM
Z_HighSpeed's Avatar
Z_HighSpeed
so this just happened to me on my way home, was driving normally and all, just threw it neutral while coming to a stop sign and the thing died on me. I installed the JWT popcharger yesterday.
I pulled off the neg battery cable for the night will see how it works tomorrow.
Old Mar 25, 2008 | 08:08 PM
06dieselZ's Avatar
06dieselZ
mine has yet to die on me
i threw it in neutral after a 4th gear redline run and no problems
Old Mar 26, 2008 | 10:14 AM
eduke23's Avatar
eduke23
anyone heard of JWT problems with the 5AT? I mean you dont throw it in to neutral which seems to be the problem so I was just wondering.
Old Mar 26, 2008 | 11:50 AM
Z_HighSpeed
didnt work too well.
reconnected the cable, turned it on let it warm up, bout 9mins, drove and maybe 3mins later it died on me.
almost died on me again about 2 mins later stuttered then caught itself. no loss in power though
my mechanic said it needs throttle relearn via dealership, but we will see
Old Mar 26, 2008 | 11:52 AM
kenpo_350Z's Avatar
kenpo_350Z
How much would the dealership charge for that? Sounds like the Stillen is the way to go. I am losing my confidence in the JWT again
Old Mar 26, 2008 | 10:19 PM
eduke23's Avatar
eduke23
Agreed, sounds like a very popular intake and comes at a great price but all of the problems just dont seem worth it.
JjL
East Canada
Jun 12, 2019 03:04 AM
OdesiTT
Sep 30, 2015 10:47 AM
RyansZ33
Sep 15, 2015 05:54 AM
